Lower radiator hose pipe crushed? - Defender Source
Old April 2nd, 2011, 09:58 PM
950rider
Matt Warren
I have a NAS 97 D-90 SW and I have recently been trying to stop a coolant leak at the radiator side of the bottom radiator hose. After tightening the hose clamp a couple of times without stopping the leak, I decided to pull the hose off the radiator and much to my amazement I found the lower radiator coolant pipe crushed on one side! The other side of the pipe (180 degrees from the crushed side) was still straight. It appears to be reducing the flow area by about 50%. Could I have done this by tightening the hose clamp too much?
Matt
Old April 3rd, 2011, 08:35 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Usually happens when someone removes the hose and uses a screwdriver or prybar to loosen and free the old hose.
Old April 3rd, 2011, 06:46 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Yes. I crushed a brand new radiator by tightening the hose clamp. It was the upper one though. I rounded it back out and went easy on the clamp.
Bill
radiator
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Custom exhust setup? Pipe size to use?? Defender50th Defender Technical Discussions 8 November 22nd, 2005 12:21 PM
4.0 heater pipe Mike Hippert Defender Technical Discussions 8 May 29th, 2005 07:37 PM
Tail pipe replacement d90Monkey Defender Technical Discussions 9 March 24th, 2005 12:10 PM
