Lower radiator hose diameter and block heater - Defender Source
Old February 6th, 2011, 11:02 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Looking to add a hose heater to my truck since it's going to be frigid again this week. Anyone know the lower radiator hose diameter on a 2.5 petrol? It snowed again and I'm too much of a sissy to go measure.
Also want to know the correct Napa version/ size of the block heater to get- goes in the freeze plug. Believe that the one for a 2.5 Diesel will fit too. RN has the part but doesn't list the size so I'm not sure which size to get at Napa.
If anyone has the corect part numbers for Napa I'd be super stoked.
Looking to have one warmer truck this week.
Alex
Old February 6th, 2011, 11:25 AM
This sounds like the same freeze plug heater that I fitted to my 300tdi. Although mine was a 400w not a 600w
Be careful installing it, I have head trouble with mine due to overtorqueing of the butterfly screw. They do provide a torque value, suggest not exceeding that...
http://forums.lr4x4.com/index.php?showtopic=18708
"Just wanted to update for the record - I ordered a Zerostart (aka Temro) 600W 'freeze plug heater' P/N 3100087 and it fits. I had to use the middle core plug (the front one is partially obscured). Size is 2.06in (52.3mm) - it's in the agricultural section of the application guide under Ford"
Old February 7th, 2011, 11:11 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
The bottom hose diameter should be 1 1/2". Rovers North has the hose heaters on sale right now. This one should be the heater you're looking for:
http://www.roversnorth.com/store/p-2...ater-1-12.aspx
Old February 8th, 2011, 08:42 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
It's a lot easier to use an oil pan heater. It just gets adhered to the bottom of the pan.
Old February 8th, 2011, 09:23 AM
Naplm00
Matthew
OR use both,
I have a pan heater and a block heater, the truck starts right up and the heat works right after start up (200tdi)
Old February 8th, 2011, 10:41 AM
They do not provide enough heat input. I would also argue that it is less work to install a lower rad hose heater.....
Old February 8th, 2011, 01:46 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
fit 300tdi too?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old February 8th, 2011, 02:32 PM
Probably. You could walk to your own truck and measure...faster than posting to these forums. A lower rad hose heater should be available at ANY auto parts store where it is cold enough to need one. No need to buy via Rovers North....
Old February 8th, 2011, 03:00 PM
kevkon's Avatar
kevkon
kevin
I prefer a block heater, but I'm putting that off.
I have one of these;http://shop.wolverineheater.com/ and it works great.
Unless you don't have coolant in your truck, there is no way a rad hose heater is quicker. The Wolverine takes about 5 minutes to install.
Old February 8th, 2011, 03:34 PM
Well, to do it "right" you need to thoroughly clean and sand the pan first.
They do not have enough heat, unless you live somewhere that really does not need one. I've had one for years, so this is first hand.
Old February 8th, 2011, 09:20 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I put a cheap lower hose heater from napa on the 200tdi. Started immediately yesterday at 0 deg F, no glow plugs time.
Sent from my iPhone using Forum Runner
Chance
Old February 8th, 2011, 10:07 PM
discotdi
Todd Miller
Land Rover
You have a part number for that cheap Napa hose heater?
Old February 9th, 2011, 12:20 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I'll have to look and see if anything is printed on the unit. It's a generic one for a 1.5" hose.
Chance
Old February 9th, 2011, 01:11 AM
mcoleman762
Mike Coleman
Originally Posted by hillstrubl View Post
fit 300tdi too?
The latest Rovers North News states that this heater is for "Late Series IIA and III, Defender V8 and TDI". Double check that your hose is 1 1/2" and it should fit.
As mentioned, your local NAPA might have something as well.
Old February 9th, 2011, 08:34 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
cool thanks.
~2008 GTI TSI
Old February 9th, 2011, 06:05 PM
discotdi
Todd Miller
Land Rover
Old February 10th, 2011, 01:07 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Here's a pic. Looks like Amazon carries it for $37.99
http://www.amazon.com/gp/aw/d/B000I8...7361156&sr=8-1
Chance
heater, radiator
