Lower Radiator Coolant Hose Cold... Normal? - Defender Source
Old October 18th, 2015, 07:30 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Finished replacing new radiator, coolant, belts and flushed the intercooler last week (200Tdi). I have been driving around the last few days without issue (other than a small oil leak on the oil coiler line). Temp gauge is just over the 1/4 line, cabin heat works, but today I was poking around the engine bay and noticed all the hoses are hot except the lower hose up to the t-stat. Truck seems to run well (almost better than before)- is this normal or do I need to bleed system somehow. Thanks.
Old October 18th, 2015, 07:44 PM
When thermostat opens, hot coolant from engine flows into radiator thru top hose and comes back to water pump on bottom much cooler. Before tstat opens, nothing flows thru tadiator.
Mark Kellgren
KM4BOR
coolant, radiator
Cold Start Question: Is this normal? samer0214 Defender Technical Discussions 6 July 1st, 2014 06:45 PM
300 Tdi Lower Radiator Hose SafariHP The Vendors Loft 2 September 15th, 2013 01:00 PM
Lower radiator hose pipe crushed? 950rider Defender Technical Discussions 2 April 3rd, 2011 06:46 PM
Lower radiator hose diameter and block heater aosias Defender Technical Discussions 16 February 10th, 2011 01:07 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
