Lower Dash Repair - Defender Source
Old April 29th, 2010, 11:23 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Lower Dash Repair
I have some damage to the lower dash from PO switches. So far I have filled them with silicone. I would like to fix them as much as possible without having to remove the dash.
Any ideas on what to use? One idea is that tool handle rubber spray in black. I think I can stamp the texture into the spray before it sets up but not 100% on it. Would really like to keep it cheap so I am tyring not to call the interior repair guys.
Alex
Old April 29th, 2010, 11:33 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I have seen/used an DIY vinyl repair kit that has a resin and different texture patches that could work. Takes some patience but you can get decent results...
http://www.eastwood.com/vinyl-and-da...ir-system.html
Old April 29th, 2010, 12:20 PM
First, I'd remove the silly-cone, since that is not a good substrate for a repair.
Personally, if I had to do it without removing the dash, I would use plastic hole-plugs from Lowe's or McMaster.com - these usually have a texture on them. With the large hole I would enlarge it and use a rectangular plug like the one up under the left side of the instrument binnacle.
The best fix would be to glue in metal plates from behind and use one of these vinyl repair kits to make it look nice.
Old February 1st, 2016, 05:04 PM
just found this old thread and I'm reviving it, since I have a lower dash that has a cutout in it I want to do away with. repairing the underlying metal piece that was cutout is straightforward. but the vinyl repair piece and looking good is the challenge. any further recommendation on how to make it look good, durable and seamless?
Mark Kellgren
KM4BOR
Old February 1st, 2016, 09:26 PM
repair and then re-cover with leather??
Old February 1st, 2016, 09:29 PM
I don't like leather...
And so does Choo Choo! Ayyyeeeeeagghhhhh!
Mark Kellgren
KM4BOR
dash
Revmoving lower dash on LR 90 gregorw47 Defender Technical Discussions 8 November 23rd, 2011 06:12 AM
A/C Lower Dash Fascia Unit Duke D90 Wanted 1 February 4th, 2010 01:51 PM
Dash repair aosias Defender Technical Discussions 4 February 12th, 2009 02:02 PM
WTB lower dash Cover tomaco1 Wanted 5 February 11th, 2009 09:08 PM
A/C Lower Dash Fascia minorthreat For Sale - Parts 2 December 8th, 2005 08:33 PM
