Low RPM knocking, ideas? - Defender Source
Old September 30th, 2005, 04:19 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Hi, all.
Recently, my 97 has started knocking when I start off the line...as the RPMs get above 1500-2000, it squares away and I don't hear a thing.
I replaces cap/wires/coil 10K ago, and have no problems/isues until now.
Timing? Or?
Thanks, all.
Tory
Old September 30th, 2005, 04:32 PM
Abrooks's Avatar
Abrooks
Tony Brooks
oil pressure light coming on?
Old September 30th, 2005, 04:34 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Possible exhaust leak, maybe a crack in the manifold? Bolt missing or lose?
Could be oil related? Checked the dipstick to see where the oil level is at?
I bought the diamonds myself so I would not have to say thank you to anyone.
Old September 30th, 2005, 04:48 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
It's not exhaust related, I'm sure of that...no pressure light...but I'll check level, I was initiallt thinking spark/timing, but interested in hearing other ideas...
Old September 30th, 2005, 04:52 PM
Has it lasted more then one tank of gas? You may have a bad tank of gas that is causing pinging.
Old September 30th, 2005, 04:59 PM
I hate it when I have bad gas!
Old September 30th, 2005, 05:14 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I would look at the cats and see if they are rattling, also would check oil pressure...or put in a gauge.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
RPM Fluctuation Billakris Defender Technical Discussions 5 March 28th, 2005 10:52 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
