Low profile roof rack options for a ROW 90 - Defender Source
Old August 13th, 2015, 11:20 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I have a few inches of clearance and still be able to get the 90 in the garage. looking for low profile styled roof "rack/base" designs options. Here is a tight fitting base on a 110 I came across. Assuming bottom of rack would be flush with ribs in roof supported by gutters or... front cage/gutter combo
Thoughts..
thanks
~ Semper Fidelis ~
Old August 13th, 2015, 11:23 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
90 in question and the damn standard garage door opening behind
~ Semper Fidelis ~
Old August 13th, 2015, 11:35 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Have a play boat, short kayak, that would be nice to be able to throw on top, or some larger items (pelican cases & large waterproof soft storage) that can be strapped down via recessed tie downs.. I could get away with two low profile cross bars for kayak
~ Semper Fidelis ~
Low profile Defender 90 are not words usually seen together
Old August 13th, 2015, 11:47 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Maybe it's just the photo, but it doesn't look like you have a whole lot to work with. How much height can you safely gain?
-Ash
Geared Restoration Co.
352-572-3236
Old August 13th, 2015, 11:49 AM
Hannibal racks have completely removable sides I think. Good flat platform.
Old August 13th, 2015, 11:50 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Will get better pics measurements tonight.
~ Semper Fidelis ~
Old August 13th, 2015, 11:51 AM
Abrooks's Avatar
Abrooks
Tony Brooks
ATV ramp?
Old August 13th, 2015, 12:09 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You can always chisel out a portion of the floor. Don't laugh, I've seen it done.
Old August 13th, 2015, 12:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
-Ash
Yeah, from that picture, you dont have much to work with.
Get your wife/girlfriend/boyfriend to sloooowly drive truck into the garage while you watch for the closest points.
My garage has a slight "ramp" going in and this affects clearance too.
Rent my
Old August 13th, 2015, 01:02 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Get your wife/girlfriend/boyfriend to sloooowly drive truck into ...
If I get the first two to assist I doubt they would be of much help at that point
~ Semper Fidelis ~
Old August 13th, 2015, 01:20 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Feeling your pain. IMO, best to go with a mockup to confirm. Then give Huff a call.
ID:	127074   Click image for larger version
Old August 13th, 2015, 01:23 PM
BlackField's Avatar
BlackField
Oscar
D110
I've been building up to making a very low profile rack now for about a year. finally have most of the tools I think I need to fab it up minus welding. The very first picture posted inspired me to want a low profile rack too.
Old August 13th, 2015, 01:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
When ever I see a post like this it makes me chuckle, back when then Disco was introduced in he UK, people where finding that the garage door that they use to clear with the family mini didn't do so with the Disco, so many just had the floors dug out.
But looks like you have room to get that header moved up and get a 8 foot door fitted.
My last garage in the UK used to be a bus depot with a 20 foot pit, heaven.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 13th, 2015, 01:36 PM
Ash's Avatar
Ash
Ash Heller
Yeah, a jig would give you the best understanding of clearance and they're a breeze to make. I have built a few low profile setups for customers dealing with this exact issue, but my personal favorite and a very popular add-on for trucks that leave here with cages is this flush-mounted Front Runner setup I designed. Obviously it's cage-specific, but it probably wouldn't be a massive undertaking to adapt it to a gutter mounted system.
-Ash
352-572-3236
Old August 13th, 2015, 01:45 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Ash, I like that idea/look!
Thanks for suggestions, I will throw some wood up there and see what I can get away with.
~ Semper Fidelis ~
Old August 13th, 2015, 03:54 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Couple of things.
1. Adjust your garage door to pull it as far forward as possible without the pull unit crashing into your pull up motor. You should have maximum clearance at the opening header now. You may have to adjust the pull arm bolts to get the door up higher than the opening header too.
2. Now you can park the D under the doorway and measure how much space you have. Most standard doorways are 78", which is not enough for any rack I know of for a D with standard BFG AT's at 31.5" new.
I have a Front Runner Slimline I with the short legs (220 mm) (they have taller ones available) and from the top of my D90 roof on the rear to the top of the rack is 3.5"
So if that will clear and referring back to the pic in post#2, you'll also need a modification to mount the Front Runner rack to your roll cage. You'll need a set of Front Runner LR3/4 FRONT mounting legs and a couple of tube clamps to clamp onto the roll bars that are steel so a mounting tab can be welded to them to attach the LR3/4 front/forward legs to. The LR3/4 has different length legs to mount on the LR factory mounting points on the roof. If you get this far PM me as Front Runner worked with me to get a rack on my D90.
Old August 13th, 2015, 06:18 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Consider cutting the header on the garage door and making a taller opening? I personally wanted to but couldn't "sell" my wife on it.
Old August 13th, 2015, 07:35 PM
Yeah, a jig would give you the best understanding of clearance and they're a breeze to make. I have built a few low profile setups for customers dealing with this exact issue, but my personal favorite and a very popular add-on for trucks that leave here with cages is this flush-mounted Front Runner setup I designed. Obviously it's cage-specific, but it probably wouldn't be a massive undertaking to adapt it to a gutter mounted system. -Ash
Very nice Ash
Old August 13th, 2015, 08:42 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Ok. Ain't gonna happen. Got 1.5 inch clearance in the rear as soon as back tires are over up over opening ledge on floor.
I am thinking cross bars best bet.
Pics
Front of top where angle breaks
Rear
ID:	127094   Click image for larger version
~ Semper Fidelis ~
90, ac, rack, roof, roof rack
Safety Devices Low Profile 110 Rack aosias For Sale - Parts 7 November 7th, 2013 04:03 PM
DI Low Profile SD Rack and RTE Slim Line Bumper Buddy Lee For Sale - Parts 4 August 28th, 2013 07:18 AM
Low Profile Winch and Bumper curry Wanted 15 November 22nd, 2012 11:40 AM
Garmin GPS Antenna - Low Profile - BNC pcscharfe For Sale - Parts 4 August 7th, 2009 11:22 AM
Low Profile Wing Top Scoop fleabus Defender Technical Discussions 1 October 14th, 2006 11:38 AM
