Low Gear Alarm? - Defender Source
Old June 20th, 2013, 02:18 PM
Kirk
Kirk
1997 D90
Low Gear Alarm?
I'm getting an audible beeping alarm when I shift it into low gear (stop vehicle, transmission in N, shift to L, shift to D). I can hear it engage and feel the torque difference. Any thoughts on what the alarm means or how to fix it?
1997 D90 Automatic w/ ARB Airlocker.
Old June 20th, 2013, 02:28 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Kirk-
You sure it's fully engaged in low? When I get that noise it is because the TC isn't fully engaged (usually followed by it popping into neutral).
r-
Ray
Old June 20th, 2013, 02:37 PM
Kirk
Kirk
1997 D90
I've driven in backwards and forwards in low gear and it feels like it is engaged but I don't drive it far once it starts beeping. I have not had it pop out to neutral but maybe that's because I did not drive it far enough. I'll check it out.
Old June 20th, 2013, 02:39 PM
The Alarm I once heard only occurred when in neutral between hi and Lo range.
Old June 20th, 2013, 03:10 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The alarm sensor may be loose or out of adjustment
Legend in My Own Mind.
Old June 20th, 2013, 03:39 PM
its warning you to get a stick shift ...
Kirk
Kirk
1997 D90
I think it's fixed. I had to drive far enough to get it to fully engage. The shift handle, or some part of the linkage, might be sticking a little which makes it hard to engage. Holding the handle in place with firm pressure and driving 200Ft seems to get the job done.
Thanks for the quick responses.
Old June 20th, 2013, 04:48 PM
Also, you should be rolling, under 10 MPH when you shift into low.
changing gear in low box jimmy salmon Misc. Chit-Chat 4 September 11th, 2007 06:04 PM
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
