Low Beam Headlights Quit - Defender Source
Old October 15th, 2003, 10:16 PM
I was driving tonight, and my headlights turned themselves off. Here is the complete description:
Parking Lights come on in switch position 1 - dash lights too
Headlights, parking lts & Dash lights dont function in switch pos 2
Hi-Beams function in flash mode, but not continuous mode.
Is this an occurance that other people have experienced? Did I burn a relay or the switch? Maybe I can just get by with some contact cleaner or tightening a fitting?
Thanks - thought I would at least ask before tearing apart the truck.
THX
Old October 15th, 2003, 10:49 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I had the same problem(8-01) and the dealer stated the switch on the column was bad due to my headlights being aftermarket upgrades.The dealer changed the switch under warranty and I have not had the same problem again.
Old October 15th, 2003, 11:02 PM
I am with Jorge, I would check the fuse and relay first by changing them with another ( any auto relay will do they are only $5 at the auto store and it is a good idea to keep a spare), this seems to be a comon problem with the original switches going bad. Jorge if the Dealer said that the headlights being aftermarket upgrades he either has no idea what he is talking about or he was tring to get you to pay for the switch. The power for the headlights is pulled through the relay, the only thing the switch does is turn the relay on and off. The stock relay is good for 30 amps. 30 amps X 12 volts gives us 360 watts 360/2 gives us 180 watts so as long as your headlights are less then 180 watts each you are cool .
Old October 16th, 2003, 08:14 AM
Thanks guys, I'll try the fuse first (of course) and they swap out the relay. Hopefully I can get this resolved today.
Old October 16th, 2003, 09:04 PM
I figured it out - the switch had a meltdown. one of the leads got loose and melted out one of the contacts. I glopped some solder all over it to get the connection back, but I'm going to go to radio shack this weekend and see if I cant rebuild the whole swich with some mica board and new contacts. Thanks for your help guys.
Old January 28th, 2006, 05:07 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
I read the other threads in my search results for "low beam" and this thread seems to be the closest match to what my 90 is having an issue with...
My PS low beam is not working but the DS is. My hi-beams both work in flash and continous mode and all lights (exterior and dash) seem to function normally. Went to pepboys just now and bought a Sylvania replacement headlamp but I'm still without PS low beam on the new headlamp.
Could this be the headlamp switch like Jim had an issue with? Any help is appreciated. Thanks.
Glenn
Old January 28th, 2006, 08:34 PM
Nope, if one side works then the switch is working! I would check the connector for the headlamp and if it looks ok then I would fallow it back to looking for cuts in the wire. Since the high beam works that indicates to me that both the ground wire and the high beam wire are fine, so you only need to trace back the low beam wire. Do you have a volt meter? That way you can figure out which wire is the low beam wire?
Old January 29th, 2006, 07:54 PM
Glenn_Guinto
Glenn Guinto
Thanks for the input Mike... I'll check tomorrow and post up some results. I'm kinda thinking the same thing about possibly the wire for the PS headlamp.
Glenn
ht, lights
Headlights not working on low beam.... KKilo23 Defender Technical Discussions 7 June 26th, 2009 12:18 AM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
