Lots of Oil around tdi cyclone - Defender Source
Old March 8th, 2015, 03:45 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Hi all-
I went to replace the manifold gasket today and did a quick inspection of the bay. I noticed a lot of oil around the cyclone and towards the rear of the engine. Any help on what is causing this so I can fix while I have some of the engine apart? Does it simply need to be cleaned/ replaced, or indicative of something bigger? Thanks.
-Chris
ID:	115529   Click image for larger version
Old March 8th, 2015, 04:32 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Two things, actually 3.
1. Clean the hose fittings to the cyclone & re-tighten the hose clamps.
2. Adjust your valves and ...
3. Replace the valve cover gasket & torque valve cover bolts to spec.
Old March 8th, 2015, 04:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Mine was only leaking where the cyclone bolts on; the o-ring had shrunk/hardened and was not sealing.
New o-ring and all good.
Rent my
Need to clean it up to see where it is coming from. More likely than not, where it attached to the valve cover. There is an o-ring in there.
Old March 8th, 2015, 05:41 PM
I had that same issue a long time ago as well, new o-ring as Jeff suggested....but I also smeared mine all the way around with some Hylomar blue as well.
Old March 9th, 2015, 05:03 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
As stated.....this is a normal fault with age and heat:I usually take off the filter and rinse to clean it out. New o ring and a smear of normal instant gasket and all is well...off you go!
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
tdi
TDI cyclone separater internals Overlander Defender Technical Discussions 11 August 26th, 2014 12:31 AM
Lots of oil in the air filter and now it won't start ceedy Defender Technical Discussions 11 August 2nd, 2014 08:12 AM
200tdi cyclone breather/vent line Naplm00 Defender Technical Discussions 4 January 16th, 2012 09:56 AM
Effect of disconnected cyclone breather michael67 Defender Technical Discussions 8 December 7th, 2010 01:14 PM
300tdi Cyclone Breather hose question (where to buy) nathanwind Defender Technical Discussions 1 November 27th, 2010 01:20 PM
