Lost only keys for my 85 ROW D90! - Defender Source
Old January 30th, 2014, 07:06 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Where does one begin on this? Most affordable easy fix? Much appreciated!
Old January 30th, 2014, 07:10 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Easiest thing would be to have a locksmith make you a new key. You can drill out the 2 breakaway bolts on the column and take it to them or replace the cylinder. I can supply the necessary parts needed either way.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old January 30th, 2014, 07:14 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Thanks! If I was gonna have a lock smith make one. Would I need or order a key from somewhere. I had three different keys and tried couple times, on over counter keys. Thanks for the help.
Old January 30th, 2014, 07:16 PM
jafir's Avatar
jafir
Jafir Elkurd
MTC6504
About 10 on the internet.
Old January 30th, 2014, 07:21 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Did you lose the door key and ignition key? Are yours the same?
Rovers 'n' Racing
407-720-9450
Old January 30th, 2014, 07:52 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Different keys. 3 actually. One for ignition and two separate for the outside
Old January 30th, 2014, 08:01 PM
jafir's Avatar
jafir
Jafir Elkurd
Are they usually different? My ex-mod uses the same key for everything.
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
It may be easier and less of a mess to tap the safety bolts with a chisel rather than drill them out.
Old January 30th, 2014, 08:10 PM
there are two types of door tumblers:
MTC6504
MUC4146
Old January 30th, 2014, 08:13 PM
if your ignition has not been changed a new key can be ordered based on the vin.
Old January 30th, 2014, 08:52 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Who does this service?
Old January 30th, 2014, 09:05 PM
http://www.defendersource.com/forum/...ad.php?t=50342
Old January 30th, 2014, 09:17 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
It's not uncommon for the trucks we've come across down here.
Rovers 'n' Racing
407-720-9450
Old January 30th, 2014, 09:21 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Originally Posted by rijosho View Post
So just a ford key and a local lock smith? Am I looking at needing to take the ignition out? the doors I can worry about them at another time. Skiing today turned into a costing event!
Also mine has a push button start under the column after turning the key this is required.
------ Follow up post added January 30th, 2014 10:22 PM ------
First experience with this. Thanks for the help fellas!
Old January 30th, 2014, 09:45 PM
I have an uncut door key... If yours are different, and you can't find one. Been saving it for a rainy day, but I know what it is like to loose your keys. My kids lost both sets for my ST, and it took 2 months to find them.
LR no longer sells keys for the NAS models.
Old January 30th, 2014, 09:49 PM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Originally Posted by woldd90 View Post
I have an uncut door key... If yours are different, and you can't find one. Been saving it for a rainy day, but I know what it is like to loose your keys. My kids lost both sets for my ST, and it took 2 months to find them. LR no longer sells keys for the NAS models.
Mine is ROW. The door key to driver door was small and off centered. The rear door had its own skinny narrow key and the ignition another! Lol
Yea I was having a great time skiing and wasn't thinking. I often thought (that I'd be screwed) if I lost my only what I would do? Guess it will play out fine!!??
------ Follow up post added January 30th, 2014 10:50 PM ------
Thanks!
Old January 30th, 2014, 11:17 PM
Google "Defender Key Blank" and post up a pic of what you are looking for.
Old January 30th, 2014, 11:43 PM
Land Rover did for the past 20 years. Based on posts above they may not anymore. I used to call Mike the parts manager @ Land Rover Mainline in Pa and the next day the newly cut key would come complete with a LR fob for $30. Mike now has his own independent parts business and others are saying LRNA no longer carries defender key blanks. FWIW there is no damn difference between a row defender 83-97 key and a NAS key blank.
Old January 31st, 2014, 09:46 AM
Jbirdlott's Avatar
Jbirdlott
Jason
1985 LR 90 200TDi
Thanks! I managed or get the driver door open! So the best direction from here? Thanks all for the direction and assistance.
Jason
Old January 31st, 2014, 09:58 AM
Bet the same key used on Jags and MGs as well. British Leyland had some habits that were hard to break.
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
95 D90! TwisteD90 For Sale - Vehicles 30 September 14th, 2005 02:54 AM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
