Lost key to locking gas cap...HELP!!! - Defender Source
Old November 23rd, 2009, 03:19 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
So I lost my only key to the gas cap....any suggestions on how to get this thing off so I don't burn it to the ground? I was thinking I would drill out the lock...BAD IDEA? Sawzall the plastic? Please help...Only have about 2 days worth of gas!!! j
Old November 23rd, 2009, 03:23 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
drill... just be careful not to go through and get shavings in your tank...
or call a locksmith, they can make a new key for you.
This happened to me years and years ago. Just cut the lock off with a knife. You can cut the top off in sections, then pull it off. Once the cap is off disable the lock and unscrew the threaded part.
GYM's Avatar
GYM
Gary
97 SW
Call a locksmith and have them make a key for it.
Old November 23rd, 2009, 03:28 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Thanks for the quick responses!!! j
Old November 23rd, 2009, 03:31 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
if you have any co2 gas spray some down the key hole freezing the two parts of the cap together. should just unscrew as one peice
3rd low and BOOT IT
Old November 23rd, 2009, 03:32 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
It's impressive that you get more than one day on a tank!
Jimmy, that's a really good idea. I would have never thought of that. You could use a can of computer duster and hold it upside down.
Old November 23rd, 2009, 04:29 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
The gas cap is actually 'unlocked' when it spins freely - and you lock the two together when you turn the key
Thus - when the two bits are frozen together ... the cap can be taken off
another way is to just pull hard on the cap when turning counter clockwise (which is what i have to do everytime)
3rd low and BOOT IT
Old November 23rd, 2009, 04:31 PM
Just cut it off, it is plastic... or shove any similar key down there and make it work.
Old November 23rd, 2009, 04:36 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Big Screw Driver?
Legend in My Own Mind.
Old November 23rd, 2009, 04:59 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
taken care of...thanks guys...used a torch then a blasting cap!!!
Old November 23rd, 2009, 05:04 PM
Old November 23rd, 2009, 05:24 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
HU?
Old November 23rd, 2009, 05:53 PM
bharris's Avatar
bharris
Brad Harris
!!!???!!! holy crap who gets only a day on a tank!!!
I believe that would be a good indicator of "time to do the tdi swap"... you burn that much fuel and a swap might actually pay for itself...
gas, gas cap
Locking Lug Nuts -- Lost the key! chris snell Defender Technical Discussions 5 August 20th, 2006 08:33 PM
Tethered gas cap??? Dredd Defender Technical Discussions 6 October 13th, 2005 04:22 PM
Gas Cap!!! Dfndr90 Defender Technical Discussions 14 August 26th, 2004 09:14 AM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
