lost ignition keys - Defender Source
Old June 24th, 2007, 08:46 PM
94SW,4.6HSE,93LWB,83 110
lost ignition keys
my keys seem to have gone on a walk about. Is it possible to have a new key cut based on the vin ?
I was already going to rekey my doors since I switched to sw but not being able to start the truck is taking a prioroity.
Old June 25th, 2007, 01:33 AM
parantaeyagn
Won Park
I got my keys cut based on the VIN and the corresponding key code number.
I works fine. Since I couldn't take the truck tot he locksmith, we had no way of checking and filing the key make it smooth on the spot, but still.... no problems.
Old June 25th, 2007, 02:32 PM
is the key code something a locksmith has or will I need that from lrna ?
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
replacing ignition key - 94 snosrfr Defender Technical Discussions 10 June 1st, 2005 01:41 AM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
