Lost a driveshaft - Defender Source
Old August 4th, 2009, 09:16 PM
tmore
Tom More
1995 D90
Lost a driveshaft
Will it hurt anything to drive temporarily without a front drive shaft?
Any resources out there for a HD driveshaft for NASD90 with 300TDI conversion?
Old August 4th, 2009, 09:33 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Remove the shaft and lock the center diff - drove my truck for several weeks that way with no ill effects.
Old August 4th, 2009, 11:06 PM
Fine to drive without in diff lock for basically as long as you want. If you have a lift, get a rebuilt Disco II driveshaft with the greasable joints and swap the flange on your t-case to a Disco II one.
Old August 5th, 2009, 10:06 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Call Tom Woods for the front shaft, best in the biz.. Or I can help you out.. Gimmie a jingle.
Keith
Big, Red and ... aaa Red..
Old August 5th, 2009, 10:56 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Last year when fuel prices were through the roof, I removed mine in hopes of better economy in my 300tdi. Drove it that way for 5 months and got about 2 mpg more. No ill effects noticed.
Dennis
Old August 5th, 2009, 05:22 PM
GYM's Avatar
GYM
Gary
97 SW
Dennis
That's incredible. Tdi D90's get what - 20 - 23 mpg? (I have no idea).
That's a 10% plus improvement in MPG just by removing the front driveshaft?
I wonder what removing the D/S would do for an NAS V8 mileage?
Old August 5th, 2009, 08:55 PM
tmore
Tom More
1995 D90
Thanks for the help all... I got it home no issues.
I thought that the u-joint was the only issue with a closer inspection it looks like I have a crack also
Guess I will be calling Tom Woods tomorrow
and running slaughter house gultch in Bailey in 2-wheel drive this weekend
Old August 6th, 2009, 01:23 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Garth, My typical milage with the 300tdi with the 4HP22 is about 23.5 With the front drive shaft removed I was getting close to 26. Everthing else is stock sizes.
Dennis
Old August 6th, 2009, 11:04 PM
Remove both driveshafts - then it won't use any fuel at all!
Old August 8th, 2009, 04:06 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
No, you'll get 0 mpg.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
drives
Driveshaft replacement Doug Defender Technical Discussions 39 July 9th, 2008 11:24 AM
Driveshaft Issues Continue...?? P1CR Defender Technical Discussions 9 July 22nd, 2004 09:12 PM
Driveshaft weights? Help! P1CR Defender Technical Discussions 11 June 30th, 2004 02:16 PM
rear DC driveshaft Abrooks Wanted 0 March 9th, 2004 01:55 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
