Loss of Throttle - Defender Source
Old July 20th, 2012, 12:57 AM
Keebler's Avatar
Keebler
Kenneth Elliott
1994 D90 AA yellow (NAS)
Loss of Throttle
After starting, the throttle cuts out intermittently. This usually works itself out after a min or two. If I press the throttle further, it becomes slightly more responsive. but has a distinctively rich smelling exhaust.
This remains fine until the ignition is shut off and started again.
I believe it may be the TPS. However, would it not be persistent throughout instead of just a mile or two into a trip?
-Ryan-
Old July 20th, 2012, 01:12 PM
probably leaky hose between MAF and throttle plenum.
Old July 22nd, 2012, 09:58 AM
Keebler's Avatar
Keebler
Kenneth Elliott
Took some ether and sprayed it throughout the engine capartment.
No surge. any other idea's?
Thanks for the suggestion though.
-Ryan-
Old July 22nd, 2012, 10:40 AM
Coolant temp sensor. Not the one that does the gauge ... The other one.
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Power loss and popping! TwisteD90 Defender Technical Discussions 40 May 30th, 2004 12:45 PM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
» Defender Registry
90
clb1994
110
clb1994
Add your Defender
