Loss of power - Defender Source
Old September 28th, 2013, 11:19 AM
Russell
Russell
2002 Defender
Loss of power
Hi...I own a 2002 TD5 Defender covered 110,000 miles. I have a on going problem that developes when the car is under load eg lond gradual hill climb. The car loses power & runs rough untill you return to flat stretch, when apon it returns to normal ! I've taken into my mechanic who connected to a diagnostic with no faults shown but we did in the process change the air flow meter which was at fault, but still the problem continues ! Any ideas ?...Thanks Russell
Old September 28th, 2013, 12:31 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Try pulling the red plug out of the ECU under the seat. if there's oil there then you'll have the classic "oil in loom" fault.
Fairly eacy to sort; new injector harness and some brake cleaner dribbled down the main harness, there's plenty on this on the www.
Also maybe the fuel pump.... does it run noisily? (a high pitch whining a lot) or do you need to crank the engine over more than usual after it's beed stopped for a while.
Sudden decrease / loss of power, bucking, stalling, etc nathanwind Defender Technical Discussions 75 September 18th, 2014 12:48 PM
odd power loss 300 tdi discotdi Defender Technical Discussions 7 August 13th, 2010 07:31 AM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Strange loss of power... OCD90 Defender Technical Discussions 3 September 7th, 2004 05:32 PM
Power loss and popping! TwisteD90 Defender Technical Discussions 40 May 30th, 2004 12:45 PM
