Loss of power - Defender Source
Old August 16th, 2004, 09:26 PM
Leadfoot
Mark Armstrong
Loss of power
I am looking for a little direction in solving the following problem ('94 D90 3.9 North American Spec).
Recently I have had a problem with loss of engine power while driving (It is not a sputtering, this is a total loss of engine) Sometimes as I am coasting down, the engine starts running again. Sometimes it cuts out and stalls. Then, a minute later, without doing anything it starts up as if noting has happened.
During this loss of power, the radio works (so I have some electrical power). The temperature of truck if normal, and outside temperature is 20 Celsius and it is not been driven hard at all just cruising at 80kmph.
If someone could start me with the order of things to check/replace (with costs in mind) I would appreciate it very much. (i.e. fuel relay, fuel pump, coil etc....)
Old August 17th, 2004, 12:20 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Mark,
I'd start by checking the connections at the ignition coil...the original spade connections get dirty and loose and can cause the problem you have. The generally accepted repair is to cut off the spade connectors and crimp and solder on some ring terminals and bolt them solidly to the coil.
Rob
Old January 28th, 2005, 03:01 AM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Did you get figure out what the problem was?
Leadfoot,
did you figure out what the problem was?
-arbi
Old January 28th, 2005, 01:38 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Also check the fuse for the Fuel Pump. Mine was badly corroded for some reason, which caused intermittant total shutdown.
Oh, and when was the last time you changed the fuel filter?
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 28th, 2005, 03:36 PM
arbik
Arbi Karapetian
Thanks for the info Hans. I just picked up the rig, and had this happen to me once. I'm taking it back to the dealership, but just wanted to see if it was something simple.
I'll have to check the fuses and have them change the fuel filter too.
-arbi
HS2.8TGV Severe power loss. Air in fuel line? DesertRat Defender Technical Discussions 12 February 24th, 2007 08:35 AM
Strange loss of power... OCD90 Defender Technical Discussions 3 September 7th, 2004 05:32 PM
Power loss and popping! TwisteD90 Defender Technical Discussions 40 May 30th, 2004 12:45 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
