Losing water from the expansion tank, no leaks/contamination, I think its the block.. - Defender Source
Old June 21st, 2012, 01:37 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Losing water from the expansion tank, no leaks/contamination, I think its the block..
Well I think its about that time. No visible leaks anywhere, radiator was re-conditioned a year ago, brass plugs around the filler tubes have clean gaskets, all hoses fairly new. Nothing around the water pump. I now have to fill the expansion tank with about 1 1/2 cup of water every 2 weeks and I can't find out where the water leaking to. No cross contamination in the oil or coolant. So I think its time for me to install that 4.6 What say ye thy experts?
Robert Deniro
Old June 21st, 2012, 06:23 PM
Same here ... Planning Tdi upgrade
Old June 21st, 2012, 07:27 PM
Have you checked the cap, to make sure it is sealing correctly? Swap on from one of your other trucks.
Old June 22nd, 2012, 09:26 AM
wantone
Rick Thompson
94 ST #1222
i have notice the same thing in my truck over the last 3 years. i fill the tank and when i check it again, it only has about 1/2 in the bottom. just like neil, no signs of leaks anywhere. truck never runs hot, and it will only leak down the the 1/2 level, no more than that so i just figured it was normal.... i have 144k miles on it
Old June 22nd, 2012, 09:44 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
I thought the expansion tank was suppose to be about half full cold.
Old June 22nd, 2012, 10:44 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Shouldn't the expansion tank settle at a certain level after a few drives? I think so... but if it is consistently going down then there is an issue.
Old June 22nd, 2012, 01:32 PM
Neil McCauley
Neil McCauley
Yeah the cap gasket is fine. I think I'll just buy another one just for the hell of it. the water actually got empty at the expansion tank one time, I literally had to fill it with a garden hose. I definately have a leak somewhere, but I'm just thinking its the perfect excuse to put that new 4.6 block I have.
Robert Deniro
Old June 22nd, 2012, 01:38 PM
giftshopduane
Chris luciano
72 Series 3 88"
Mine was doing the same thing, drove me crazy. I couldn't find a leak anywhere, no puddles nothing. It was the small line under the tank, it would leak down the hose when it felt like it but wasn't puddling anywhere. What about on the backside around the valley pan gasket?
Install the 4.6 either way.
Old June 22nd, 2012, 02:02 PM
Neil McCauley
Neil McCauley
valley pan has a few cracks in the front and is a little dirty but I don't think its leaking. I think I'm just going to plan to swap the motor out this summer.
Robert Deniro
Old June 22nd, 2012, 02:56 PM
check the back of the heads
water
Flojet waterpump for on board water tank kellymoe For Sale - Parts 5 June 24th, 2010 05:16 PM
Water tank question Overlander Defender Technical Discussions 13 July 24th, 2007 02:20 PM
water in fuel tank? CaptMidnite Defender Technical Discussions 3 January 5th, 2007 10:43 AM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 04:05 AM
