Losing/Adding Coolant - Page 3 - Defender Source
Old August 30th, 2013, 09:36 PM
There's no gasket on a D90 that's that big of a deal to replace, so as long as it is not a cracked block, it really isn't that big of a deal. Its all nuts and bolts.
Old September 16th, 2013, 08:03 PM
Just to update, we figured it out. We put the pressure tester on it and waited about an hour before it started to leak. Once it started, it was a constant drip. It ended being the hose that comes out of the front cover behind the water pump. The radiator had a slight seep, but nothing that would cause any stains on the driveway. A new hose kit should take care of the issue.
coolant
Engine Coolant what kinda rover4x4 Defender Technical Discussions 12 May 17th, 2009 11:02 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
