Loose steering - Defender Source
Old October 15th, 2004, 05:06 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Loose steering
I tightened the box and with the front end off the ground when I turn the steering wheel the movement is transfered to the wheels. With the front end down and the steering wheel is turned there is significant slack int the steering, maybe 2+ inches. Could it be the tie rod ball joints? If so, easy fix. Any other tests I should be trying?
Old October 15th, 2004, 08:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
With that much slack, if it's the ball joints it should be visible if somebody watches them while you steer at a stop. You would see the tie rod move but the knuckles not moving. Could also be in the box itself, the rag joint in the steering shaft between the steering wheel and the box, also check the joint at the end of the steering arm attached to the box.
Myself, I'd check that ball joint on the steering arm first. Again, if it's THAT loose it should be easily visible.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 15th, 2004, 08:42 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Hans,
Thanks for your input. I never seem to have anyone around to help. Guess I need to make more friends. I will find someone to turn the wheel while I check it out. Ball joins are cheap and I am hoping that is the main problem.
Thanks again,
Kevin
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
directional switch install/pulling steering wheel? Eric_S Defender Technical Discussions 12 May 17th, 2004 09:13 AM
