loose rear drive shaft bolt at the brake drum - Defender Source
Old April 12th, 2011, 06:08 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
One of my rear drive shaft bolts is loose and I can't seem to get it to tighten, it just spins in the e-brake drum.
Any ideas short of pulling the drum off?
Old April 12th, 2011, 06:51 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
With the drive shaft off it is really easy to pull off the drum. The adjustor bolt is at the bottom forward side. You might just need a new bolt.
Land Rover 110
Old April 12th, 2011, 07:04 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Not good ideas.
You could weld it.
I warned you.
Tony
1984 110 "Smokey" (sold)
Old April 12th, 2011, 11:32 AM
dchapman
Daniel Chapman
1999 D1
It's easy to pull the drum. Just do it.
Old April 12th, 2011, 12:07 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Pull the driveshaft(4 bolts). Remove drum(1 screw). Remove flange(1 nut). Remove large c-clip and replace cross threaded bolt. TADA!!! Reassemble and you're done.
Old April 12th, 2011, 03:45 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep, do it right or don't do it at all.
Mike Hammond
Old April 12th, 2011, 06:24 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So other than the 4 bolts and nuts, are there any other parts I need to replace?
Old April 13th, 2011, 03:19 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Replacing the drum brake with an X-Brake is a good idea.
Tony
brake
Rear drive shaft needed. MAR!? ini88 Wanted 15 October 1st, 2009 09:12 AM
Rear brake calipers staying engaged. FlaD90 Defender Technical Discussions 4 April 12th, 2009 07:29 PM
OME Springs & GBR Drive Shaft J4hand For Sale - Parts 8 January 20th, 2005 10:20 AM
vibration around 20 mph Rick Carlisle Defender Technical Discussions 19 August 25th, 2004 07:41 PM
