Loose bell housing bolts rattling around inside... - Defender Source
Old February 19th, 2013, 08:01 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Over the weekend I removed a 110 transmission because of bell housing noise and clutch failure.
Inside, 2 of the bolts that connect the bell housing to the main gearbox had come completely loose inside. One had jammed the clutch release fork and rendered the clutch inoperable. The inventory consisted of 2 bolts, 2 washers and a locating spacer.
The other 4 bolts were a little tighter than finger tight.
Cleaned everything up and re-torqued all the bolts inside the bell housing with locktight after cleaning the threads out with thinner using Q-tips. Obviously replaced the 2 rattlers.
Replaced the pilot bushing, clutch release fork, pressure plate and release bearing... the driven plate disk looked new.
Now we are all set to go back together with a 1.22 T-case.
In the future, anytime there is an open belhousing, will remove all the bolts, clean the bolts and threads with thinner, and replace them all with locktight. It's time consuming, but worth the prevention of a future mishap.
RDavisinVA
Old February 19th, 2013, 08:07 AM
Land Rover: A loosely associated collection of British automobile parts moving in generally the same direction.
Old February 19th, 2013, 08:34 AM
I had the same thing happen with an r380
bolts
nut inside bell housing punter Defender Technical Discussions 0 October 23rd, 2011 11:10 PM
short bell housing lt77 late suffix orionpco Wanted 2 June 27th, 2010 09:14 PM
300 tdi short bell housing pendy For Sale - Parts 9 February 6th, 2009 11:22 AM
WTB: Bell Housing for R380 NashvilleRover Wanted 9 August 17th, 2008 07:32 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
