Looking to get past the speed limiter... - Page 2 - Defender Source
Old October 4th, 2016, 07:15 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
Originally Posted by Red90 View Post
The vehicle speed sensor is a box in the middle of the speedometer cable.
Rob and I were talking about this subject over the weekend, I have put in 4.14 gearing, and running 265 tires, my fuel was cutting off around 94mph. So if by reading this correctly, If I take the speedo cable out completely and go to a GPS speedo I will solve the cutoff problem?
Old October 4th, 2016, 07:27 PM
Just disconnecting the wire would do the same thing. The speedo has nothing to do with the ecu signal. But removing the signal causes other problems. The VSS changes the idle mode and without you get stalling problems.
Old October 4th, 2016, 07:57 PM
Yep, the VSS is the issue. Disconnecting it will cause it to stall when returning to idle, which is worse.
We need a RRC ecu with a higher limit or a new eprom
Nice thing is a RRC ecu is plug and play and cheap. Just need to drill new mounting holes for it on the 95.
Found this page with some good info
http://www.actproducts.co.uk/2011/lu...gnostic-notes/
also looks like the 23 tooth sprocket will return the speedo to "Normal" as well
I looked at Rovergauge tonight while hooked up to my truck and there is no way to "Flash" it in, hard programed eprom so that figures
95' D90 - Mostlydaily driver..
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 06:02 AM
Silly Girl ? about Tire Speed Rating ?? RoverChic Defender Technical Discussions 2 September 24th, 2005 09:55 PM
Code 48: Base Idle Speed? thug1313 Defender Technical Discussions 2 April 29th, 2005 10:52 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 08:44 PM
Help Speed Limiter evilfij Misc. Chit-Chat 10 May 7th, 2004 09:04 AM
