Looking for cost estimates for repairs to 97 SW - Defender Source
Old March 2nd, 2007, 04:51 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Am considering buying a 97 SW and had a LR dealer do a pre-sales inspection. Seller agrees to be flexible on price. My question is how much would it cost to have the following items addressed. I know there's probably not enough info for you but let's assume the worst case scenario and then the most likely scenario and make your best estimate of what a good indy mechanic would charge (including parts.) I can't do these things myself.
1. Transmission (auto) doesn't shift out of second until warmed up and reaches a high rpm. Assume a total swap out of a good, used auto transmission (assuming they're readily available, are they?) and then a rebuild.
2. All four brake rotors under spec.
3. Transfer box leaks
4. Transmission line leaks
5. Radiator leaks
6. Needs two tie rod ends
7. wiper motor, hood cable, A/C inop
Which ones are typical, no problem Rover issues and which should make me run away quickly? Thanks.
Old March 2nd, 2007, 07:58 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
Exclamation
IMO... Call Rob Dassler AKA Roadside Rob on this board. Shop time might be anywhere from $75-100/hour. Est. repair hours for ea. fix are in the shop manual.
Rob Dassler
Southwest Rovers LLC
505-872-7818 (shop)
Ebay Store
You can source the parts through links available through members on this board for most of the stuff I saw. There's Rovers North, British Atlantic and Rovers Down South that I use the most. Just me...lot more out there. Rob sold me a T-Box and had a R-380 (manual) transmission if I needed it. Most of the people in our club source parts like that from Rob. There are others though. Here too, as a matter of fact. Don't want to piss anybody off.
Leaks...They all leak. How bad and what caused it is the question. Mine looked like a rain forest underneath when it was up on a rack at my pre-purchase inspect. Dealer did a 30K mile service for $1100 and the bleeding stopped.
Recommend taking your time. And BTW there were problems with my truck that the dealer didn't mention. Can you get another D owner up there to take a look? And...Sometimes you can get an overreaction from a dealer too. They told me the head gasket was bad, when it was only a rocker cover...Big difference in cost.
ME huh? Have you taken a real close look for rust? Bulkhead, under floor mats, threshold for rear door, doors (esp. bottoms), gas tank skid plate, rear door and/or spare tire carrier hardware, and frame at a minimum. Check for caked mud underneath and scrape it off with a screw driver...If it's red...
There was a guy selling a blue D from ME that looked like cheese grater about a year ago.
Does the seller belong to this board? Last but not least..Get ready to buy a good socket set, PB Blaster, grinder and sawzall for seized bolts. Once you see the repair costs you are going to be motivated to do some yourself.
"I ain't lost!!, ain't NEVER been lost...<Scratching head>Been a might confused fur a few hours...but I ain't never been lost."
Old March 3rd, 2007, 07:14 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Gary, is this local?
I can give it a look if you'd like, or give me a call if you need prices.
I have much of what you need in stock, other than the tranny, which is only a couple of days (shipping)away.
Matt Browne
Old March 3rd, 2007, 09:39 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Gary, I don't think you could find a much better guy than Matt to take a look at that thing for you...
"It's not a Jeep"
Old March 3rd, 2007, 12:00 PM
Shake
Red 94 D-90 #428
See, Gary? No way I would move on that truck now w/out Matt taking a look at it. If it's not local, ask a Defender owner in that area to take a look. IMO almost any owner can spot some problems outside of drive train and electronics, that an non-owner might not. We all pay "tuition."
Unless the guy is giving it away, I don't think anybody would jump ahead of you and just say"I'll take it."
You don't have to reply, but how many miles does it have on it and what is he asking $$?
Old March 3rd, 2007, 12:36 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Matt and I have spoken but the truck is not local. He did give me an approximate price that would make the truck a good deal even after having the work done. The seller is noodling over it and we're talking again on Monday. Thanks everyone for the help.
Old March 6th, 2007, 01:16 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile
1. Transmission (auto) doesn't shift out of second until warmed up and reaches a high rpm. Assume a total swap out of a good, used auto transmission (assuming they're readily available, are they?) and then a rebuild.$100 to $2000
$300 parts and 4 hrs might as well do pads $150
Let it leak unless its real bad
$200 parts and 2 hours
5. Radiator leaks
$500 Parts and 2 hours might as well do radiator hoses $100
$100 and 3 hours then front end alignment $100
$200 wiper and 2 hours
Hood cable $25 and 1 hour
AC anywhere from a charge $100 to a full rebuild $1500
None of the problems are a big deal just make sure of the rust situation.
Alot of the above you can do yourself with a basic set of tools and a little time.
Speaker placement - '97 D-90 SW owners Chaucer Defender Technical Discussions 4 October 4th, 2010 02:44 PM
1997 SW side doors, top and rear door avail, and more from 97 LE wicks For Sale - Parts 21 April 28th, 2010 02:53 PM
97 D90 SW stuck in reverse. woldd90 Defender Technical Discussions 9 September 9th, 2009 09:56 AM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
97 SW Rear Hoop Pix Yousef dnewman9 Defender Technical Discussions 4 July 20th, 2004 01:55 PM
