Looking for ARB locker installation shop - Defender Source
Old February 13th, 2006, 11:51 AM
RoverWrecks
M R
Does anyone have any recommendation here in Central Florida who can install some ARB lockers?
Old February 14th, 2006, 11:00 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Have you already purchased the ARB's?
Old February 14th, 2006, 09:22 PM
RoverWrecks
M R
No not yet
Old February 14th, 2006, 10:09 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
GBR will send you one in a 3rd member in a bucket, bolt it on and install the compressor, lines and switch.
Old February 15th, 2006, 09:53 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
DYI
http://www.defendersource.com/tech/arb.html
If you buy it from Bill (GBR) he will press new barings on for you
--Benjamin Franklin
Old February 15th, 2006, 11:00 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
That's exactly where I was headed with my first post.
Old December 4th, 2006, 07:20 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by mhansen
Did anyone do the install in the front? The rear seems fairly easy as you can pull the half shaft. I am curious to know what to watch out for and what is the easiest to do when doing the install on the front diff (i.e. what is the minimum you have to unbolt?)
Winter is here and that seems like a nice garage project.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 4th, 2006, 07:32 PM
Monkeyboy
Guest
Posts: n/a
I have yet to find anyone that agrees with me, but I think its easiest to unbolt the entire swivel from the end of the asle tube and slide it out. A nice chunk of 2x4 will hold the swivel out enough for the axles to clear the diff so you can pull it.
Remember that regardless of what you do, you'll probably have to hang the brake caliper up on a piece of wire so you don't stress the brke lines.
Old December 4th, 2006, 11:41 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
That is exactly what I did when I installed my dads and my front lockers this last summer. Hint: buy a racheting box end 12 point wrench to take the bolts out.
Cheers
--Benjamin Franklin
Old December 4th, 2006, 11:54 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I agree with you Keith.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 5th, 2006, 08:25 AM
Monkeyboy
Guest
Posts: n/a
Phew, now I feel better
Aaaack, just realized that I've gotta get a trans picked up from JCRover!?
Yup, I'm still a doofus.
KAA
Old December 5th, 2006, 09:26 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I agree as well huge time saver & way cleaner
Old December 5th, 2006, 12:35 PM
MonLand
Loic Fabro
Cheers
Kewl! :-) I wasn't sure if that was even possible! Definitely seems like a lot of time would be saved.
How strong does the wrench need to be? [i.e. go with a cheap alternative or would a lifetime-warranteed be required]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 12:48 PM
Monkeyboy
Guest
Posts: n/a
I always use the non-ratcheting Craftsman to break the bolts loose then the cheepie ratcheting box end to take 'em out.
Don't forget the thread locker when you reinstall them ... this means that you'll be cleaning all the goo off the bolts and the holes - I use brakecleen - before assembly.
Note how I assume that everyone's swivels are a dirty as mine ... ymmv
KAA
Old December 5th, 2006, 12:50 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Go expensive! your not working on a Chevy! Clearance is an issue with the cheapo version, between the bolt head and the axel shaft.
I had to use a small hammer and a regular box end wrench (12 piont) to break the bolts loose. Use alot of PB Blaster every day for week before you start the job.
EDIT
KAA you beat me to the punch!
--Benjamin Franklin
Old December 5th, 2006, 01:08 PM
MonLand
Loic Fabro
EDIT
While I am at it: what type of seal did you use between the swivel end and the axle end? The standard paper version just regular RTV type thing? I am personally puzzled between both..... paper is cleaner in my option, but then RTV never leaks......
RTV is a pain to undo because it really glues things together plus you have to be careful to put the right amount (not enough it will leak somewhere, too much it will go inside where it is not supposed to go). And RTV is typically cheaper (once you factor in the shipping cost of the paper seals.....).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 01:27 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
I used RTV (Right Stuff Brand) if you use the method of dismounting the swivel ball, you would have to cut the paper gasket anyway to get it around the axel.
It is true you don't want too much squirting on the inside, but how much is too much, and what will it hurt to have it beaded up or globed up inside the axel? The front bearings and CV's are sealed and self contained, lubed with grease / swivel lube, so diff gear oil just has to lube the diff. Unless you modified by removing the inner seal.
When I removed the third member it had a lot of RTV globed around the inside with no ill effects.
One more thing, if you still have front sway bars you will have to take the right side mount to the axel off to remove the swivel ball mounts. Also the tie rod will have to be removed. It is probably bent anyway, so upgrade with one from Keith.óRover Tracks.
--Benjamin Franklin
Old December 5th, 2006, 01:34 PM
MonLand
Loic Fabro
I still have my front sway bar. And as I use my truck as much off than on the road, I'll keep it! :-) [What this also means is that I don't drive it enough.....]
I just replaced my tie rod after bending it surfing on a log, so I am not looking in replacing it just yet! ;-) But it might be a good time to sleeve it....... Crap another alignment to do.... :-( Maybe later....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 01:49 PM
I undo the 7 bolts at the tube as well, however you have to re-loctite them (blue) or they do loosen up. 12mm racheting wrench. Start all the bolts with a non-racheting wrench hitting it with a hammer.
Old December 5th, 2006, 02:54 PM
MonLand
Loic Fabro
Cheers
What did you do with the brakes? Undo them and then attach them to the spring? Or can you pull enough of the swivel to just allow enough clearance to remove the 3rd member?
MonLand
1995 D90 NAS
1996 Discovery NAS
installation
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
Locker - Front or Rear bd90 Defender Technical Discussions 6 January 14th, 2004 09:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
