looking for a pitman arm - Defender Source
Old January 25th, 2013, 09:47 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Hi everyone, So I am upgrading my front steering arms and I need/want to change my pitman arm from the standard defender one with the ball joint to the RR classic style pitman arm which is open and accepts a standard tie rod end from the drag link. Does anyone have one of these pitman arms and would be willing to sell it...????
thanks
Old January 25th, 2013, 10:02 AM
The Dro
Dro
1988 Ninety
Have no fear The Dro' is here...
PM Sent.
Old January 25th, 2013, 11:09 AM
USLandy's Avatar
USLandy
Andrew
defender 90
RRC, that is the wrong one but I do appreciate the quick response. The one I am referring to is the tapered hole one, which on Atlantic is 160... So I am trying to find a used one for much less.
The later model Classics (92-95) have them too. I guess I am going to be calling all the local scrap yards!
Old January 25th, 2013, 11:11 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Try Rovahfarm
http://rovahfarm.com/RangeRoveropeni...er%20parts.htm
-Ren Ching
Old January 25th, 2013, 11:22 AM
USLandy's Avatar
USLandy
Andrew
defender 90
SMOB, already tried them. Trevor is a great guy, they are now my main supplier of parts due to their customer service which they have given me.
Old January 25th, 2013, 02:14 PM
smob's Avatar
smob
Steve
XOMIGOD - that's the first time I've heard that Trevor hasn't a usual Rover part..
-Ren Ching
Old January 25th, 2013, 02:25 PM
I have one on one of the legions of steering boxes kicking around in the barn. If you can wait for me to retrieve it, it's yours for stamps.
Old January 25th, 2013, 03:10 PM
Any of the rover part out people will have one. You need the drag link too as it is a different length between the two set ups.
What do you plan to do about a steering damper?
Old January 25th, 2013, 04:17 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Andrew, I have a RTE damper kit(less the damper) for sale. It will work with your RTC damper, too.
Old January 27th, 2013, 02:28 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Brett, I wish I would have caught that earlier. I already got the relocation bracket and new drag link through rovertym.
I did actually end up finding a drop arm (after about 10 phone calls and a long time on the interenet) at a somewhat local scrap yard and just got it yesterday morning. But I greatly appreciate all the responses!
Old January 28th, 2013, 01:00 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Sweet, sounds like you're all set. The RTE rods are very Bling Bling!
Old January 28th, 2013, 01:10 PM
The Dro
Dro
1988 Ninety
EDIT... I was looking for the thread showing a failure on a drop arm and found that Lucky8 has them for DIRT CHEAP.
http://www.lucky8llc.com/Products.aspx?ProductID=5831
Dood... get a new one. It's cheap insurance.
If you decide to re-build... IMO it's not worth the hassle...
http://www.lucky8llc.com/Products.aspx?ProductID=5843
Old January 29th, 2013, 01:31 AM
USLandy's Avatar
USLandy
Andrew
defender 90
the new pitman arm i need from rovers north is 160... that aint cheap when I can order one from England and get it sent here for cheaper than half of that. Its just a pitman arm too. Remove the rust and give it some paint and it's good to go!
Old January 29th, 2013, 08:15 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
A used one shouldn't have any rust because undoubtedly the power steering was leaking all over it. :D
Old January 29th, 2013, 11:12 AM
The Dro
Dro
1988 Ninety
I never mentioned RN... They do have a vast inventory and great customer support. I've purchased from them A LOT.
But for this part... I recommend going to a different vendor.
Did you check the link I mentioned on my previous post?
Justin at L8 has it for $33.
That works to your advantage when removing it.
But the effort in rebuilding it IMO it's more than the $33 a new one costs.
Old January 29th, 2013, 11:44 PM
USLandy's Avatar
USLandy
Andrew
defender 90
True you did not mention RN but I said for a price to show how expensive it is. The pitman arm you are showing is not the one I was looking for. I needed the one without the ball joint, rather the open tapered end which a standard tie rod end would fit in.
Old January 30th, 2013, 09:50 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I just checked, since both my D90 and Disco have the "permanent lube of the pitman" feature, I think you are mistaking and this is not a "leak" but a well designed/engineered feature. On classic LR, it probably came standard, but I'm sure it'd be part of the HD package on a 2013 RR.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 11th, 2013, 11:18 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
I'm looking for the same thing, tapered pitman arm that accepts standard tre from disco or late rrc. Anyone have a used one?
Defender 110
Old June 11th, 2013, 11:29 AM
The Dro
Dro
1988 Ninety
Call Justin at Lucky 8.
Old June 11th, 2013, 04:17 PM
myoverlandrover
josh
109
Will do, but still looking for used as well..anyone?
Defender 110
Tam tam ... Tam tam. Pitman arm puller near beacon NY needed. leastonce Defender Technical Discussions 5 August 12th, 2012 08:52 AM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
