Looking for a Good Ground - Defender Source
Old November 25th, 2007, 08:13 PM
Arnzo
Andrew Arnott
1997 Defender 90
Hi
I have a 1997 D90 and I am adding heated seats for the winter. I have the seat elements in and I have run the wires into the tuffy box and then forward through the center console up to the fuse box. There is a screw to the right of the fuse box that looks like its meant to be a ground. Do any of you fine folks know for sure if it is a ground? Also any suggestions for where I should pull power? There are two 20 amp "AUX" fuses that I'm thinking I should tap.
Old November 25th, 2007, 09:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Can always add in an aux fuse box, and take the power plus do the ground right at the battery.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 25th, 2007, 09:54 PM
-Hans
That is what I would do...
Old November 27th, 2007, 11:42 PM
Arnzo
Andrew Arnott
1997 Defender 90
Thanks guys. I am looking to set my seat heaters on switched power. I fear that I will accidently leave one of the seat heaters on and drain the battery if I go direct to the battery. The screw I am referring to is directly to the right of the fuse area and is in the metal casing the surrounds the fuse box. I'm hoping this is a ground and the AUX fuses will work as good taps. I guess I'll have to try it out.
Drew
mpgs for diesels? Z O O R O P A Misc. Chit-Chat 145 April 26th, 2013 04:02 PM
Jump seats from Defender 110 Mooreland cloth good condition. Set of 4 inboard facing Northface For Sale - Parts 2 August 1st, 2005 05:20 PM
seems like a good deal on ebay.. Campbell Misc. Chit-Chat 5 December 13th, 2004 04:55 PM
Good Rad price? Burke Misc. Chit-Chat 2 November 23rd, 2004 04:02 PM
Good thing he had the jack! PT94D90 Misc. Chit-Chat 3 October 10th, 2003 02:10 PM
