Longer Wheel Studs?? - Defender Source
Old April 2nd, 2010, 07:42 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
My stock LR wheel studs are about 1/4" too short when I fit my spacers. My research shows that longer 16mm studs may not be available, or are really expensive. Has anyone found a source for longer studs?
Semper Fi!
Old April 2nd, 2010, 08:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can pound them out and shove in standard 16mm threads and tack them to the back of the hub in whatever lenth you want. I switched to 5/8 fine and normal nuts when I did mine just to make my life easier. This is for steelies though.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 2nd, 2010, 08:09 PM
http://forums.lr4x4.com/index.php?showtopic=19338
britpart FRC7577
Old April 2nd, 2010, 08:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
I have the "longer" ones anyway for my alloy wheels, but they are just a tad too short for the spacers. Zeus only says they are 15mm longer than stock, which doesn't help me as what is "stock?" There were stock ones for steelies, and then "longer" ones for alloys.
Semper Fi!
Old April 2nd, 2010, 08:56 PM
i think they are all the same actually except for the zeus and britpart ones. the zeus are 2 or 3 times the brotpart price IIRC
Old April 3rd, 2010, 01:12 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
What the heck kind of spacers did you get Jonathan? All the ones I have and have seen you just bolt it on then use your lug nuts on the studs.
http://cgi.ebay.com/ebaymotors/WHEEL...Q5fAccessories
Old April 4th, 2010, 07:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
I'm running normal spacers- the EZ Accessories ones. The nuts they provide still leave about 3/8" to 1/4" of extra thread on the nuts. I would guess that I am using about 80% of the threads on the nuts. I am sure I am fine, but since I was swapping hubs for my spline conversion I figured I would attempt to at least swap in some proper studs.
I'll just Loctite the hell out of them! Below is a pic - it makes it look worse than it is. But that is the nuts on the longer LR studs.
Semper Fi!
Old April 4th, 2010, 07:49 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
Thats Scary not sure I would want ato run them that way.
Old April 6th, 2010, 06:43 PM
Wolf Fabrication
Sterling Archer
'08 D3
I have finished my axle conversion and the 24 spline hubs I have have slightly longer studs. I also noticed the one hub I was concerned with had the shorter studs. Here's a pic of what they look like now.
Semper Fi!
Old April 7th, 2010, 04:52 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The Zeus studs are what you need. I'm running them on my 110 they are 15 mm longer than the alloy weel studs.
Mike Hammond
wheel
Extended Wheel Studs RyanS Defender Technical Discussions 57 August 21st, 2015 05:43 AM
LR3 bolt pattern and wheel studs trailerman Defender Technical Discussions 0 May 27th, 2006 10:32 AM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
