Longer studs with spacers - Defender Source
Old June 22nd, 2015, 02:17 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I put 30mm spacers on and the original studs should be a bit longer to get a few more threads engaged...how should I go about replacing with longer studs? Do they come out of the hubs out do I need new hubs? Where does one buy them...thanks...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 22nd, 2015, 03:33 PM
Yes you can press out the old studs and press in new ones. There should be threads here on it, and all the vendors should sell longer studs.
Originally Posted by pendy
I'm here for the D's
Old June 22nd, 2015, 05:32 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Found them... FRC7577 .... anyone know who carries them?
Old June 22nd, 2015, 05:52 PM
Google the part number. Plenty of choice.
Old June 22nd, 2015, 05:54 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Someone had tried these which are domestic and the same place i got the spacers from... Wheel Adapter Studs 16X1.5
Old June 22nd, 2015, 07:20 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Just got a PM from the John who used them with spacer adapters....they are approx 57mm vs 60mm so should be perfect...and they are cheap from the above source...
Old June 24th, 2015, 10:34 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Be sure to post some photos of the Defender after you install the spacers. I'm thinking about doing the same.
Old June 24th, 2015, 11:09 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Here is a picture of my Defender after using the cheap eBay 30mm spacers. I'll reinstall only after sourcing better quality nuts. Thinking the crap Chinese steel is too soft, but YMMV. At least use locktite as it is not like you can go back in to retorque the nuts with the wheel on.
BTW - the NAS factory studs are plenty long to clear the spacer nuts. The factory lug nuts on the spacer studs is fine as well.
Name:	wheel spacers.jpg
Old June 24th, 2015, 11:46 AM
phoenix37's Avatar
phoenix37
john
Ouch Russell.. Glad you are ok.. Did it snap off?
Old June 24th, 2015, 12:03 PM
down_shift's Avatar
down_shift
Russell
All five spacer nuts backed off and remained captive between the spacer and rim. Perhaps I didn't torque them. Don't know. The word of caution here is there was ZERO indication the wheel was about to fall off until a slight steering wheel wobble during a right hander a mile earlier that went away after the curve. The wobble was faint but noticeable. At first thought low air pressure and the KM2 sidewall ribs lugs were in play. Then the wheel fell off... instantly. Just kept it straight and pulled off to the side of the road. The rotor left a nice scar on the asphalt. Zero damage to the D besides this unique flat spot on the rotor. I got lucky.
ID:	123533   Click image for larger version
Old June 25th, 2015, 05:42 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Holy crap! Glad you're ok Dude.
ac
Longer Wheel Studs - FRC7577 Wolf Fabrication Wanted 0 July 16th, 2010 08:37 PM
Longer Wheel Studs?? Wolf Fabrication Defender Technical Discussions 9 April 7th, 2010 04:52 PM
1994 Rear Bench Seat For Sale•••••••MAKE OFFER wife no longer finds proposal to turn JAD For Sale - Parts 3 February 13th, 2007 05:05 PM
ARB Lockers.... Can't Wait Any Longer mhansen Misc. Chit-Chat 8 March 21st, 2005 12:44 PM
Why women live longer than men GliderKing Misc. Chit-Chat 8 September 17th, 2004 01:05 PM
