longer front radius arms? - Defender Source
Old October 31st, 2012, 02:16 PM
Saw this picture from Custompinoyrides:
http://farm3.static.flickr.com/2547/...63475eda31.jpg
After staring/drooling at it a bit, I noticed that the front axle is further forward than normal. So much so that they cut the front wings a bit to clear the 35" tires.
I'm guessing that this is done by installing longer front radius arms.
1. Who, if anyone makes these radius arms?
2. Let's say that the new radius arms move the axle 2-3" forward from normal. How does one handle the offset of the springs on the perches? Is there some kind of spring perch relocation that needs to be done?
Seems like a quick and easy way to stretch the wheelbase of a 90 a bit without going into a full 100 inch build.
Old October 31st, 2012, 02:20 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Move the front spring buckets forward on the frame and install longer radius arms. But then you have to think about the effects on your steering geometry - drag link and steering box binding, longer driveshaft, panhard relocation, etc.
Semper Fi!
Old October 31st, 2012, 03:38 PM
Cube II's Avatar
Cube II
Michele
1997 D90
FYI,
kits are becoming available here...new longer radius arms, new pitman arm, new correction plates for springs, bla bla bla...
Alternatively, mostly in the UK, Gigglepin arms have been used to stretch the wheelbase, mostly on challenge trucks...they use Johnny Joints at the chassis, and new mounts (old ones must be cutted off).
Alternatively, David "Buck" made his own with a lathe, a welder and stock arms...
P.S.
The Defender in the pic has stock radius arms, and a 3" lift kit.
Here's the specs list:
Specifications and Modifications
1998 Land Rover Defender 90 Pick-Up
300Tdi 2.5 liter diesel engine
5-speed manual transmission
ARB Air Lockers, front and rear
ARB Air Locker air compressor, with tire inflation line
Land Rover Salisbury heavy-duty axle shaft, LH rear
Concept One racing bucket seats, 2 pieces
Concept One 4-point seatbelts, 2 sets
Warn M8274-50 Electric Winch, with 6 HP motor & freewheel winch drum
Scorpion Racing Extreme Suspension Kit
Scorpion Racing Coil Springs +3”
Bilstein Shock Absorbers 5150 Series
Super Pro Polyurethane Suspension Components
Simex Extreme Trekker Centipede Tires, 35 x 10.5 x 16
Discovery Steel Rims, custom bead locks
MJ Lee differential protector, front
Optima Yellow Top Batteries, 2 pieces
Dual battery charging system
Battery cut-off switch
110 ampere alternator
Halogen sealed beam headlights
Auxiliary lights front, 4 pieces
Auxiliary lights rear, 2 pieces
Custom modifications: — winch bumper, roll-cage, roll-bar, skid plate, rear differential protector, front suspension guard, rock sliders, tree sliders, rear lamp guards, recovery swivel hooks, wing top protectors, tree limb risers, raised air intake, swing-out spare wheel carrier, tarpaulin bed top, body panel checker plate protection, heavy duty steering rods, front axle retaining chain, radiator mud screen, jerry can mounting, steering wheel, storage locker.
Ground anchor
Perforated aluminum platform, 2 pieces
Hi-Lift Jack
Shovel
Jerry can
Fire Extinguisher, 2 pieces
First-Aid Kit
Pintle hook rear
Dyneema plasma synthetic winch rope, spare
Two-way radio
On-board video camera
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old October 31st, 2012, 05:51 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
RTEs are a bit longer than stock. 5/8 iirc if you go anymore than an inch you're going to be moving everything Jonathan mentioned.
Old November 1st, 2012, 07:44 AM
Thanks guys...hadn't even thought of the steering mods. I guess one could move the steering box forward a bit also.
I really like the look of the defender with the front wheel moved forward a bit.
Old November 1st, 2012, 08:15 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Oh that would let me steal more leg room I could move the footwell forward. Hmmmm
Thanks for the post
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old November 1st, 2012, 08:39 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Here you go:
Extended wheelbase kit
MUDSUX
Old November 1st, 2012, 08:56 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by MUDSUX View Post
Sexy kit, but ouch!
COR4 is the old Equipe by the way.
Semper Fi!
Old November 1st, 2012, 12:28 PM
probably easier to cut and weld custom links and coil overs.
or get a disco
Old November 1st, 2012, 02:15 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Kang needs a life coach
Old November 2nd, 2012, 08:09 AM
Or a wifey.
Old November 3rd, 2012, 08:06 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Or a wifey.
no way a wife helps you with these kinds of decisions...well actually she will...she will just tell you no to everything Rover!!!
Old November 3rd, 2012, 01:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Cube II View Post
FYI,
Hey,
Sweet! I got a shoutout on D-90 in 2012! I feel warm inside!
The steering angle will soak up a mild push forword. Up to about 2in if I remember. The spring plates would need to be changed or modded to go that far. On mine I lenthened the arms 8in. This won't give much more travel, but it will lower your antidive numbers, which will make the truck perform noticably better off-road. It's a good mod. I was able to get to a true 90 degree approach angle with 40's and a winch.
I miss my truck.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 3rd, 2012, 07:28 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Buck - good to see you on the 90 board again. A couple questions to those with the kit or mod (this would be way down the road for me but always fun to think of cool projects especially since I have been playing with the welder more and more). Anyway:
- With a 2" move of the front axle - is the ride noticibly better?
- How much if any do the fenders need to be cut? Or can you get away with just the fender flares.
- Does the front bumper need moving/modding? Let's say its a Rockware.
-Stock axles can be used but just an adaptor for the spring perches?
A D-95 sounds like it would be pretty potent on the trail and a little longer might be more forgiving around town too.
Old November 4th, 2012, 08:57 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Would using Johnny Joints at the frame connection of the arms be beneficial if the springs are retained? It seems like it wouldn't add much if anything unless they are running with dislocation cones etc. (if I remember correctly, the truck in the link is running cones)
Old November 4th, 2012, 03:51 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You don't get any benefit doing that, other than a more robust connection. The bind takes place in the axle side bushing. A longer radius arm will make that binding less, but so little I doubt you would notice it. I had to mod them to use all of 14in shocks, and even doing that it took a lot of force to use it all during articulation.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 4th, 2012, 06:23 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Is it me, or is this place just warmer & fuzzier with David back?
Old November 9th, 2012, 04:07 PM
Dave, do you know of a limit on how far the rear axle can be pushed back before the A-frame or A-frame ball joint needs modification? I'm assuming this moving of the rear axle is done with longer rear trailing arms. I guess I just realized that if one can buy a few inches in the front, one could also buy a few in the back.
Old November 10th, 2012, 07:49 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Devon 4X4 makes an extended trailing arm and A-arm extender for their trayback kit which will give you a 100 inch wheelbase. Problem is the rear fuel tank. You would have to extend the frame and tub - or lose the tub and build a trayback.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old November 10th, 2012, 08:57 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
A disco has a 100 inch wheelbase I believe. Would be easier.
- Charles Eames
Castor corrected bushings vs. cranked radius arms RiftRover Defender Technical Discussions 17 April 17th, 2015 11:23 AM
Front and rear arms USLandy For Sale - Parts 0 November 21st, 2011 11:29 AM
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Front radius arms bushing swap, how to jack ? JFD Defender Technical Discussions 11 October 4th, 2011 10:57 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
