longer front radius arms? - Page 2 - Defender Source
Old November 10th, 2012, 01:16 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Longer trailing arms = more articulation
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old November 10th, 2012, 02:22 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Hey,
Sweet! I got a shoutout on D-90 in 2012! I feel warm inside!
I miss my truck.
We're getting intimate, uh?
I miss your truck too, the new owner is not even a member of this board...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old November 11th, 2012, 01:40 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Dave, do you know of a limit on how far the rear axle can be pushed back before the A-frame or A-frame ball joint needs modification? I'm assuming this moving of the rear axle is done with longer rear trailing arms. I guess I just realized that if one can buy a few inches in the front, one could also buy a few in the back.
Hi,
I think it depends on what you are expecting the truck to do. When you make the a-arm assembly longer you are decreasing the angle of horizontal separation. This will make the stress the upper joints see go up. That said, I moved mine back 10in. The joint is remarkable. Never had an issue. I did however, rip the a-arm off the frame side. I had to rebuild the mounts. All in all, it was stout.
Just as a tip in general, if you can find a way to add triangulation into the lower arms, your roll axis angle drops and your truck will drive REMARKABLY better. Cheers
------ Follow up post added November 11th, 2012 06:40 AM ------
I know. Mike. He's nuts. He has rolled it twice already.
------ Follow up post added November 11th, 2012 06:42 AM ------
Yes, the math is settled. But in this application, not really. You can't make them long enough to make a difference.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 11th, 2012, 02:51 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Devon 4X4 makes an extended trailing arm and A-arm extender for their trayback kit which will give you a 100 inch wheelbase. Problem is the rear fuel tank. You would have to extend the frame and tub - or lose the tub and build a trayback.
Here
http://www.devon4x4.com/index.php?op...uild&Itemid=41
Ed's truck has a side mounted fuel tank so that's not a problem.
A three point linkage gives lots of front articulation.
Shortening the front chassis bumper mounts improves the approach angle.
Here's the link for the 110 also very cool in the flesh
http://www.devon4x4.com/index.php?op...back&Itemid=46
Mike Hammond
Old November 11th, 2012, 08:55 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Originally Posted by Buckon37s View Post
Hi,
Back when my white and yellow 90s were set up, both with rear coilover shocks. The white had stock trailing arms and the yellow had lenghtened trailing arms (new mounts welded to the frame - 8" longer arms). The yellow could most assuredly out-articulate the white and by a large margin.
Chris Hinkle
Old November 11th, 2012, 12:47 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
So your talking rear lower links, and not front radius arms? If thats the case, it definately doesn't make a difference. Unless you mounted a hiem on the extended ones and are confusing the bind you felt with the lenth you added. It will help with the rear steer, but will cause your pinion to lower at droop and limit what your driveshaft will accept.
My new buggy has 30in front links, and 18in of travel and rediculous articulation.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 11th, 2012, 01:30 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Did have heim joints
Chris Hinkle
Old November 11th, 2012, 09:49 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yep,
It didn't have anything to do with lenth. You even raised your link mounts, which will offset your change.
BTW, if you still have that truck, a few changes to the lower links would make it handle way better and limit the rear axle steer you get. I can send you an excel sheet with the numbers if you want.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 12th, 2012, 07:25 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Actually, the 90 drove great - high speed daily driver (supercharger). Multiple cross country trips to Colorado and Moab back in the 90s, where it did pretty much everything without an issue and then drove back home. Now it's a 110.
Chris Hinkle
Old November 12th, 2012, 09:33 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
What's up front? 3-link?
Old November 12th, 2012, 11:16 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I thought mine drove great. Till I fixed it. Then I thought it was really great, till I drove a car set up really well. I thought that was amazing. Till I drove a car set up near perfectly.
Anyway, the 110 in your avatar looks great!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 12th, 2012, 12:30 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I would be interested in seeing that sheet. A while back I saw a worksheet that required many different specs that require putting the truck on a scale and what not but since mine is still in parts there was no way for me to figure that out. If you have the info, presumably for a 90, I would love to see it. FWIW I'm working on a 100".
PM incoming
Old November 12th, 2012, 04:03 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
That was before 3-link existed - at least before it existed for defenders.
Chris Hinkle
Old November 12th, 2012, 04:25 PM
Hoosier, what magic did you have up front?
Old November 12th, 2012, 04:48 PM
Cube II's Avatar
Cube II
Michele
1997 D90
History.
Michele
D90 VNTdi
[O]===[O]
Old November 12th, 2012, 07:30 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Dual 12" fox shox on each side, one position sensitive. Dual rate 89 RR rear springs on the front if memory serves. Nothing else. Rear was 14" fox coil-overs (dual-rate setup) using a modified SG upper shock mount.
Chris Hinkle
Castor corrected bushings vs. cranked radius arms RiftRover Defender Technical Discussions 17 April 17th, 2015 11:23 AM
Front and rear arms USLandy For Sale - Parts 0 November 21st, 2011 11:29 AM
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Front radius arms bushing swap, how to jack ? JFD Defender Technical Discussions 11 October 4th, 2011 10:57 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
