Long Range Fuel Tanks... 1984 ROW 110 - Defender Source
Old September 29th, 2013, 09:47 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Did a search through the archives and looked online, but no joy.
I am looking for a long range fuel tank or an extension to the stock tank to hold another 20 gallons or so.
The problem is every web site has tanks for the 1993 - 1999 110 and nothing is recommended for the earlier 110.
Gustavo showed me a really nice plastic tank on display at Conclave that filled the underside panel under the wheel well and had 2 short filler hose fittings. The tank is connected by 2 short hose sections instead of the long filler hose and the fuel passes through the aux tank, fills up the stock tank and then fills up the aux tank. Typical add on tank, but again it was not for the early 110.
Any suggestions for vendors?
I would build some, but am tied up with the Mercedes OM617 conversion kits at the moment.
RDavisinVA
Old September 29th, 2013, 10:27 AM
http://www.safari-equip.co.uk/shop/i...arch-tank.html makes metal ones.
Call Justin that was his display.
Old September 29th, 2013, 11:20 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Just ordered a DA4545 that I think will do the job from www.lrdirect.com
RDavisinVA
Old September 29th, 2013, 12:58 PM
what did that cost with shipping? This has been on my bucket list for a while.
Mark Kellgren
KM4BOR
Old September 29th, 2013, 01:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Just under 300 quid including shipping.
RDavisinVA
Old September 29th, 2013, 01:14 PM
not bad! That's the model I need as it works with the rollcage support due to the notch.
Mark Kellgren
KM4BOR
Old September 29th, 2013, 01:52 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you want, can provide feedback when it arrives.
RDavisinVA
Old September 29th, 2013, 04:01 PM
Yes!
Mark Kellgren
KM4BOR
Old October 1st, 2013, 03:29 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Earlier tanks should be the same as 1993-1999. Maybe the filler neck is slightly bigger, but that's all.
Old October 1st, 2013, 03:40 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Thanks, we'll see when it gets here.
I'll post some pictures because we have quite a few 83 - 88 ROW 110s here.
RDavisinVA
Old October 5th, 2013, 12:13 AM
ArcadiaBBQ
Alex
Defender 110 300tdi
Does this tank use a separate filler neck or does it piggy back onto the original tank?
I was hoping to use something like this tank for my WVO project.
Old October 6th, 2013, 06:55 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have a set of steel tanks that came on a Saudi spec 110 . Same description, small fenderwell tank that is sandwiched between main (very much larger) and filler. For a diesel truck unless someone wanted to set them up with an external pump for petrol.
......just read the whole post and see you have it sorted but I'll leave this up in case anyone else is looking.
Matt Browne
Old October 6th, 2013, 11:51 AM
Matte, exact type, pics and price?
Mark Kellgren
KM4BOR
Old October 14th, 2013, 07:20 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
working on it. Im on the trails for a few days but will give it a look when I return to the shop.
Matt Browne
Old October 14th, 2013, 08:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Did a trial fit last Friday before leaving for MAR and the tank from LRDirect actually extends the main tank, so on petrol models there is no need for an additional fuel pump. Pretty nifty setup, but with the odd shape a line is needed to fully drain the added tank. There is a welded bung that came with a barb fitting which I will connect to the diesel return line fitting on the original tank.
Only real issue was having to figure out how to install it because there are no instructions included.
It took a little while to figure out that the original filler assembly is removed and a later style filler is included, but you need the body gasket and filler cap from the later Defender for the 1986 we have.
Will get some pictures and Matt feel free to post some of your setup as well.
RDavisinVA
Old October 14th, 2013, 09:56 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Yeah, I wasn't meaning to clog up your thread flogging my junk. Just trying to be helpful.
Matt Browne
Old October 14th, 2013, 10:07 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Matt:
You're cool with me... and your posts directly relate to the thread.
Again feel free to post pictures if you have time.
RDavisinVA
110, 1984, fuel, fuel tank
NEW aluminum fuel tanks, stock and long range.. revtor Series Technical Discussions 19 March 23rd, 2015 01:25 PM
1984 110 up on eBay rijosho The Flea Market 26 June 28th, 2012 11:32 AM
Defender 110 Aux fuel tank ECR For Sale - Parts 9 November 16th, 2006 03:21 PM
