Loctite??? - Defender Source
Old August 31st, 2005, 10:41 AM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Loctite???
I have my new OME suspension to install. I have got great information from a lot of guys on the install, but have one guestion.
Should I use loctite on the bolts when I put everything back together on the suspension?
Matt...
Old August 31st, 2005, 12:03 PM
sure why not, but even then I think you should re tourque everything after a few miles. I thin kthe blue loctite would be the best
Old August 31st, 2005, 03:57 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I just put mine on last weekend. To me, it made a world of difference in the handling of the truck. It was good before, but now it is awesome. Me and a bud put on four springs and shocks, first defender we have done, and it took about 2.5 hours. And yeah I used blue loctite on mine.
Bill
'95 Alpine SW 339/500
Bill
Old August 31st, 2005, 04:00 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Bil,
Very cool. Did you use a spring tool, or did the springs pretty much just drop out?
Matt...
Old August 31st, 2005, 09:44 PM
kolvedic's Avatar
kolvedic
Bill Lewis
On the back, we just supported the frame on a jack and jack stands and let the rear suspension drop, careful of the brakelines. Those springs came out easily after we removed the cheapo stock retainers.
On the front, we did the same procedure supporting the car on the frame with jack stands. The suspension drops a quite a bit, but just not enough to pull the springs out. We put the stock little parabolic jack in between the axle and frame and jacked it apart the rest of the way and pulled everything out and put the new ones in without a spring compressor. Again, just be careful of the brake lines. I read that jack trick somewhere (probably on this site) and thanks to whomever out there! Its a snap.
l8r,
Bil
Bill
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Front cover? Bowtracer Defender Technical Discussions 12 May 10th, 2005 03:26 PM
Wow... this sucks mattwhite Defender Technical Discussions 13 October 22nd, 2004 11:39 PM
