Loctite 270 equivalent? - Defender Source
Old July 10th, 2016, 05:50 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Hi folks,
I'm about halfway through my rebuild of my front axle corners and happened upon the recommendation to use Loctite 270 on the stub axle bolts. The reasoning for the 270 specifically (I suppose) is that it's supposed to both provide a good block for oil to leak past the swivel housing and also provide a resistance to backing out.
I've got Permatex 29000 (green) on hand, but it doesn't seem like it's the same sort of product.
What do people use in lieu of Loctite 270 or instead of that, what would you recommend for affixing the sub axles to the swivel housing? (Note: Loctite 270 is used *a lot* through the land rover shop manual...)
Edit: and it's VERY difficult to get in the US!
Old July 10th, 2016, 06:17 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Use 262 for now and order some 270 off eBay?
Old July 10th, 2016, 06:29 PM
270 is obselete, which is why you can't find it
From: Designed for the permanent locking and sealing of threaded fasteners - Henkel
LOCTITE 263 is the recommended replacement for LOCTITE 270™.
I personally use loctite blue on all my external fasteners (but I'm crazy)
$270 Macbook cgalpin Misc. Chit-Chat 15 December 18th, 2009 11:12 PM
D-90.com equivalent for Range Rover? Method PHX Misc. Chit-Chat 3 December 9th, 2005 11:49 PM
Loctite??? Dfndr90 Defender Technical Discussions 4 August 31st, 2005 09:44 PM
hylosil equivalent 48vphantom Defender Technical Discussions 2 February 8th, 2005 09:54 AM
