Locker debate - Defender Source
Old November 18th, 2010, 08:15 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Locker debate
I got in a debate today with a friend over the best lockers. I feel that ARB's are the best because you can open your diff and leave it open. He says ARBs have lots of problems on the trail due to air lines, to many connections to get loose, etc. He believes something like a detroit or other limited slip is the way to go for durability. What do you think? What would be the ultimate set up for wheeling and driving on the road?
That is why it is called a short cut. If it was easy it would just be "the way."
Old November 18th, 2010, 08:29 PM
For the average off-roader, a selectable locker is better IMO because you can try an obstacle on skill alone first. If that doesn't work, then you can lock it up and get over the obstacle.
If you do competitions, mudding or serious off-roading, a detroit or similar is probably better.
Old November 18th, 2010, 08:31 PM
e2orlando.com
Eddie
DII Diesel
Kam is the best!!
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Locker Question RickM Defender Technical Discussions 14 April 9th, 2006 12:41 PM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Locker - Front or Rear bd90 Defender Technical Discussions 6 January 14th, 2004 09:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
