Locked out RRC - Defender Source
Old November 22nd, 2017, 02:28 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Locked out RRC
Feeling pretty stupid right now.
I haven't had a chance to address a faulty remote so I have to manually lock the door. I'm not able to lock the truck with the key either so whenever I need to lock the truck I depress the lock from the back door then shut the door.
Unfortunately I left the key in the ignition and don't have a spare. What's the best way to get into the truck?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 22nd, 2017, 02:34 PM
Contractor's Avatar
Contractor
Will
1969 IIA
You got AAA?
They will get inside in about 2 seconds.
Old November 22nd, 2017, 02:35 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Call fire dept or police for a slim jim
Old November 22nd, 2017, 02:49 PM
NADA
Paul - use a pry bar and carefully pull the top corner of the door (LHS = top rt corner looking at it) away and wedge something in the gap. Then use a long piece of rod to hit the unlock.....this is the way AAA or others will do it. Fairly simple.
Old November 22nd, 2017, 03:08 PM
lordhelemt's Avatar
lordhelemt
Paul
Its a '94 classic so no unlock button. Was able to get a coat hanger on the button but it won't pull up. Also tried to grab the rod with the coat hanger but i'm either not doing it right or it's not strong enough and unbends pulling on the rod.
Will see if i can find a slim jim.
Thanks!
Old November 22nd, 2017, 04:02 PM
If you are able, remove the 4 top hinge screws on the upper tailgate.
Old November 22nd, 2017, 04:41 PM
lordhelemt's Avatar
lordhelemt
Paul
Didn't think of that.
Napa had a slim jim in stock. 2 hrs goofing around with a coat hanger with no result. 20 seconds with the proper tool and it's open.
For anyone in the future I was able to lift the mechanism by sliding the bar to the right side of the lock barrel, bent end of the tool facing out, and it opened by lifting.
1995 RRC LS3 plus restore Brewie212 Truck Build-up's & Restores 45 February 14th, 2018 10:16 PM
Feeler 1995 RRC lwb (all California) D90Overkill For Sale - Vehicles 24 December 29th, 2017 01:57 PM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
» Defender Registry
NAS D90
Sned
BUD
BUD86
Add your Defender
