Locked out of SW..... - Defender Source
Old February 2nd, 2012, 07:05 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I'm an idiot and locked my key in the D. Does the wire hangar trick work or am I going to have to break a window?
Old February 2nd, 2012, 07:43 PM
superjc
Jason Cordoba
1994 D90
Call AAA, they have this slick little airbag that will open the door just enough for the guy to get a device through to hit the switch and unlock it.
Old February 2nd, 2012, 07:57 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Well, I got in. Let's just say its scary easy. Stout metal lock boxes shouldn't be just for Soft tops....
Old February 2nd, 2012, 08:06 PM
I use the wire hanger all the time.
Old February 2nd, 2012, 08:14 PM
My ST 90 door key worked in my SW, and two of my buddies 90's. Sam, if it happens again, I will mail you my key to use and send back.
Old February 2nd, 2012, 08:29 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks for the offer Scott. I'm going to get off my butt and get a few spares made and wire them to the truck. I went for a run with just the lock key, put it in the console after the run, and then shut all the doors when I got home. Im going to have to find the little stubby key somewhere first.
And this could be the easiest vehicle I've ever opened with a wire hanger. Not that I expected anything else really.
Old February 2nd, 2012, 08:55 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Great suggestion! Where should I locate it? In the battery box? I doubt most people realize where they are located...
Old February 2nd, 2012, 08:57 PM
I swear its impossible to lock yourself out of a Defender.
Old February 2nd, 2012, 09:12 PM
Most people I give the key too cant figure out how to start it.
Old February 2nd, 2012, 09:25 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Forgot about the battery disconnect. I'll have to add that to the battery box makeover list. And I like the idea about the fuel pump disconnect, though if someone really wanted the truck, theyd find a way to take it.
My great grandad wired a shotgun to the door of his prohibition era still to "discourage" trespassers. Wish I could do the same to the truck. .
Old February 2nd, 2012, 09:59 PM
One of the early NASCAR Guys?
Old February 2nd, 2012, 10:04 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Nah, just an old timer gold miner/rancher/mayor/sheriff/bootlegger in central Idaho. All at the same time......
Old February 2nd, 2012, 10:43 PM
It's dead easy to open most car doors with a coat hanger. Also, I can't lock my 90 without the key.
Old February 2nd, 2012, 11:00 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
If you didn't have a 97' I'd say you already have a damn good urban theft deterrent... A clutch and MT.
I locked my keys in, and realized I'd left the sunroof cracked. Turn the wheel all the way open, flip the little retainer, pop out the glass, and got to slide in through the sunroof like a tartan Bo Duke.
Old February 3rd, 2012, 10:12 AM
GYM's Avatar
GYM
Gary
97 SW
I can't either.
Old February 3rd, 2012, 10:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by GYM View Post
I can't either.
Me too!
Semper Fi!
Old February 3rd, 2012, 10:27 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Its sorta funny and sad how many times this is actually the case. Those pesky three pedals.
http://www.tampabay.com/news/publics...-shift/1204496
http://baltimore.cbslocal.com/2011/0...y-stick-shift/
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old February 3rd, 2012, 10:42 AM
my theft plan is to splice the fuel shutoff solenoid with an extension and run it through a toggle switch mounted inside my tuffybox. then they either have to rewire the solenoid or break into the tuffy box to get away with the vehicle. ignition won't do a damn bit of good for them. that is of course, if they make it past the factory battery cutoff on NAS110's. Suck that hoody!
Old February 3rd, 2012, 11:01 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
When I was in "Queens" I was talking to a guy at a beer garden, he told me the best way to protect a Defender was to park it yourself where it can not be picked up with a flat bed. They just lube the wheels and tow it up and it is gone.... They figure out how to get it running inside the chop shop..
Old February 3rd, 2012, 11:40 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I can't lock mine without the key.
I can't either.
Here's how to lock it (the '97's anyway) without using the key. With the door open (duhh), Put downward pressure on the lock button, then pull outward on the interior door opener handle (latch) to it's maximum. Suddenly, let go of the latch while pushing down on the button, the lock button goes down. It gets easier with practice.
------ Follow up post added February 3rd, 2012 08:43 AM ------
See post # 22
------ Follow up post added February 3rd, 2012 08:48 AM ------
IF you have sliding rear windows, take a "yard stick" (metal ones work best) slide it in between the windows horizontally, push on the window catch until it's compressed, take your other hand and slide the movable window towards the rear, reach in & push the door button up, you're in.
95 SW to ST back to SW aka rover Defender Technical Discussions 13 January 9th, 2012 11:02 PM
SW doors off 1997 SW $700 ron For Sale - Parts 5 August 30th, 2011 08:37 AM
1996 Disco 35s, locked, etc... WBDISCO For Sale - Vehicles 0 November 2nd, 2005 10:41 AM
1997 Alpine White SW Offers over 30k... Eric Siepmann For Sale - Vehicles 7 November 3rd, 2004 01:52 PM
which is worth more ST or SW ron Defender Technical Discussions 3 March 2nd, 2004 09:12 PM
