Lock Cylinder removal - Defender Source
Old July 28th, 2010, 12:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
What is the correct tool to remove a lock cylinder?
With a thule rack there is a key that makes the cylinder pull out. Is there a similar tool for a door locks?
Old July 28th, 2010, 01:40 PM
For the front doors? I disassembled the lock and the cylinder has a small spring loaded catch that releases it from a larger carrier. Tool used ... small screwdriver.
I'm guessing a Thule lock has an extra tumbler that can be released with a special key. You wouldn't want a special key to exist for your land rover ...
Having said that my new locks open with my old worn out key!
Old July 28th, 2010, 02:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
well with thule it only works if the lock is unlocked
This is for soft top doors
Old July 28th, 2010, 02:44 PM
I don't lock my doors. Actually, I don't even know if they lock. I just fold my seats forward, and keep my dash open with exposed wires, so that people think it's already been broken into.
Old July 28th, 2010, 03:51 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Generally me too, as a throwback from being a former soft-top Jeep owner, I'd rather they got in easier than cut open the top or broke a window. Costing me even more $$ and slowing them down by approximately nothing...
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 28th, 2010, 04:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have only locked my doors twice. WOndering about replacing the handle. Need to move the lock over
Old July 28th, 2010, 06:10 PM
61rover's Avatar
61rover
John Crouse
Changing lock cylinders on the front doors is really easy if you remove the door handle. The rear door is a little harder as you have to push a pin into a little hole and disengage the cylinder. No special tools required.
Old July 28th, 2010, 06:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
does it matter i am talking the handles on soft top doors?
Old July 28th, 2010, 07:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
ITs easy, remove the handles, and you will see a small hole where you put a punch or small screw driver in the hole and push down a detent.... The lock will come right out...
Legend in My Own Mind.
Old July 28th, 2010, 07:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
cool thanks
SW Rear Door Lock Removal mpsteil Defender Technical Discussions 2 November 2nd, 2009 08:15 PM
How do I remove a lock cylinder if I don't have the key? evilfij Defender Technical Discussions 5 May 1st, 2009 01:45 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
