Location of main ground - Defender Source
Old January 18th, 2009, 10:36 PM
JRW's Avatar
JRW
94 D90 ST #1247
Anybody know where the main ground from the battery is supposed to connect under the chassis? While replacing the stereo I noticed mine is just flapping around under the truck. The wire comes off the negative terminal, connected to what I believe is a transmission mount and then is not connected anywhere else.
Thoughts/Pictures?
Old January 18th, 2009, 10:40 PM
flynn23
Scott Kozicki
97 NAS D90 SW
Funny. I was going to ask the same question. My dash lights blink and sometimes the odometer flashes garbage colors, especially in the rain. This makes me think think that the ground is loose or corroded.
Old January 19th, 2009, 11:26 AM
On my truck I used an unused hole in the frame and attached the cable from the battery on the outside. On the inside of the frame rail I attached another ground cable and ran that over to one of the bell housing bolts. I sanded that spot on the frame on both sides to assure good conductivity and used di-electric grease to assure it stays that way. I also have another ground that runs from the frame to one of the starter mounting bolts.
Old January 19th, 2009, 11:51 AM
Grover's Avatar
Grover
On mine, the ground goes from the battery to the DS frame rail, then to the trany.
Old January 19th, 2009, 02:18 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
That's what I have, but I also have a loose ground cable from the engine that probably should be attached somewhere..... When I get some time, I'll open the WSM....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 20th, 2009, 11:56 AM
JRW's Avatar
JRW
94 D90 ST #1247
I think I have it figured out...
I think I figured out the routing for the main ground from the battery. Look at the attached PDF photo I have labled and let me know your thoughts.
http://wandrisco.com/docs/DefenderMainGround.pdf
ground strap mattdh Defender Technical Discussions 5 November 25th, 2006 04:35 PM
'97 main ECU and mounting box dmarchand For Sale - Parts 1 December 11th, 2005 09:19 PM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
» Defender Registry
DD
Howski
Green Mile
Jdc0430
Add your Defender
