Load Area seats - some questions - Defender Source
Old January 16th, 2014, 07:47 PM
Looking at some exmoor load area seats - i want something with head rests and that is easily removed from the rear entirely, as well as not having brackets in the middle of the load area space (which interferes with double scuba tanks)
the Forward facing flip up seats - anyone know if they are easily removed? - or have a way to unbolt the seat from the bracket etc?
The lock and folds have a number of brackets - but same question there as well.
95' D90 - daily driver..
Old January 16th, 2014, 08:15 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
They are meant to be a permanent install. I don't think it would be easy to setup otherwise. you could do a bench seat.
Old January 16th, 2014, 08:26 PM
i have a bench seat right now - may keep it since it can be easily removed
but if the head rest style seats can come out easily then i would prefer those.
Old January 17th, 2014, 09:45 AM
michael67's Avatar
michael67
Michael White
110 Tdi
For the older ones (the non-lock and fold), there's a bracket that's bolted to the side that has pins the seats slide onto. It's easy to take out the seats and it usually takes a minute or two fighting the pin alignment when putting the seats back. The bracket is held in place by two bolts. When the seats are not present, the pins overhang about an inch. Seats can be set up forward or backward facing. They are high back, so do not have a removable headrest.
If you're also installing seatbelts, you'll need to put a bolt in the middle of the floor between the seats. Since the seatbelts need to pivot on the bolt, it's not some that can be made flush very easily.
I have these installed in my 110. Let me know if you want any more details.
seats
Load area fwd facing seat piekas Wanted 3 June 28th, 2011 01:02 PM
Load Area Seating - D90 DNinety Misc. Chit-Chat 10 April 22nd, 2011 06:48 PM
4 Rear Jump seats, mint dmarchand For Sale - Parts 11 October 15th, 2005 03:00 PM
Exmoor Trim seats loykd Misc. Chit-Chat 38 August 20th, 2005 05:15 AM
FS: Four SW Jump Seats from 95 D90 DJ Menasco For Sale - Parts 4 December 19th, 2003 12:28 AM
