Live Wire - Defender Source
Old June 23rd, 2005, 08:37 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Live Wire
Who knows the colour of the live ignition wire behind the dash.
Thanks Jimmy
Old June 23rd, 2005, 08:59 AM
You are talking the wire that gets power when the ignition is turned on right IIRC White with purple stripes (second key position). Brown is always on from the battery (I know this for sure) , white is for accessories (first key position) and the last one I think white with red strips is for the starter (last key position).
Just thinking about it again, if you are sitting in th drivers seat looking at the ignition switch, the bottom left should be brown (always live) top left should be white (accessories) top right should be white with purple stripes (the one you want) and the bottom right should be white with red stripes (starter).
Old June 23rd, 2005, 10:30 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Thanks Mike
Old June 23rd, 2005, 11:30 AM
No prob, are you doing some quick wiring before the trip down?
Old June 23rd, 2005, 12:28 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i was,i have no red with purple stripe. white with red stripe, white with orange stripe(orange is bottom right,use that one???)
still need to wire lights and whinch which wont take long just connecting to new fuse box
other than that all loaded and ready to go
top right??
Old June 23rd, 2005, 12:59 PM
I never said red with purple! OK so red with white, is it in the top right? If so use that one it should turn your test light on when you put the key in the on position.
Old June 23rd, 2005, 02:49 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
I got the biggest laugh out of reading this thread. Red with purple stripe! No, wait, brown with green polka dots! Wait, now it's flashing!
"Looking at Lucas wiring, it seems as though a demented drunkard took what should be easy and made it into a monster. " - Referring Link
Where does this wire go ? (electrical question) norros Defender Technical Discussions 4 April 20th, 2005 11:45 PM
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
