Little yellow wire - Defender Source
Old March 15th, 2009, 03:57 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Little yellow wire
I just bought a new creeper to make it easier to get under the rover and was looking around and found a yellow wire under the drivers side near the chassis that wasn't plugged into anything.
After looking through my workshop manual I came to the conclusion that it is the vehicle speed sensor MFI connection. The thing is, I can't find where it connects to. Anyone have any feedback?
Old March 15th, 2009, 06:48 PM
Do 94's have the mechanical speedo or use a VSS from the transfer case?
Old March 15th, 2009, 07:13 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I'm almost sure it has the VSS.
Old March 15th, 2009, 08:09 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
94s have a mechanical speedo, but there is a little box that is goes thru which sends a signal to the computer. When it thinks you've hit 85mph it cuts off fuel. The little transducer is on the drivers side on top of a bracket. Speedometer cable comes in from the transfer case - goes thru the box and then on to the speedometer. If you follow the cable from the transfer case, you can feel it. I don't remember the wire color and the electrical diagrams are at the shop.
Old March 16th, 2009, 08:51 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The yellow/white wire that is a single wire with a Lucar plug on the end is the ground trigger wire for the handbrake warning lamp.
The EFI speed sensor wires are in a loom that has 2 wires and a larger round black plug on the end.
Hope that helps
Email:
Old March 16th, 2009, 09:43 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
will take a picture tonight as i have the floors out and the tunnel.
3rd low and BOOT IT
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
