Little help with bolt tq - Defender Source
Old June 10th, 2015, 03:44 PM
scrubs
henery
1974
Hi,knew it one time while installing the bellhouseing but for the world of me cannot find it again.
Bellhouseing bolts to gearbox bolt torque,
felt like in the 55lbs area to me.
Also replacing the input shaft seal is why,what are the torque settings for those 6 on the gearbox input shaft plate?
Have read on how it's done and looked at LR on line manual but haven't seen what to torque them to
Old June 10th, 2015, 03:50 PM
LT77?
Clutch housing to gearbox bolt. 48-59 lb-ft
Front cover to gearcase . 16-21 lb-ft
In the front of the manual. Section 06, page 3
Old June 10th, 2015, 03:51 PM
scrubs
henery
1974
Thanks, download manual doesn't show those pages
Old June 10th, 2015, 03:53 PM
You are downloading the wrong manual then....
Old June 10th, 2015, 03:55 PM
pdf Land Rover Manuals | Landroverweb.com
Defender 90 & 110 Workshop Maunual series. Part 1, section 06. The 200TDi specific stuff is in the supplement section.
Old June 10th, 2015, 04:02 PM
scrubs
henery
1974
Yep, that's where I got it, pages I believe words should be are blank, most helpful illustrations though
Will ask, is the seal also a dry fit, selfsealing?
3 bolt to 4 bolt LHD PAS box conversion kjva Defender Technical Discussions 3 April 3rd, 2012 06:20 PM
95 3.9l 10 bolt or 14 bolt head kolvedic Defender Technical Discussions 12 June 25th, 2010 11:40 PM
Little help on an I.D. tomaco1 Defender Technical Discussions 0 February 9th, 2008 12:49 PM
A little help needed..... Defender50th Misc. Chit-Chat 15 September 18th, 2006 07:43 PM
Brand new 4.6 installed in 1995 D-90... need a little help. Heath Defender Technical Discussions 8 October 20th, 2004 03:44 PM
» Defender Registry
DD
Howski
Hilda
badvibes
Add your Defender
