Lining up distributor and oil pump shaft - Defender Source
Old November 3rd, 2007, 06:20 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I've been struggling for an hour now to try and get the distributor to accept the oil pump shaft with no luck. Do people just put the distributor on the cam and crank it until lines up? Is there some trick i'm missing? I would prefer not open up the oil pump and turn it from there..
Old November 3rd, 2007, 06:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yep, thats basically it. Spin the engine slowly, preferrably by hand if you can, and it will drop down into place once the tab and slot align.
Just make sure you know where TDC on the compression stroke is, to set up the timing.
My oil line fix
My 100k stopped odometer fix
Old November 5th, 2007, 08:15 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I don't remember from my old setup but I finally got frustrated enough to remove the oil pump and pull the shaft out. The distributor did not sit all the way down on the timing cover. The seal on the distributor sits just inside the opening on the timing cover. However there is a space btw the seal and the "lip" about an inch higher. Given by the lack of dirt in this area it seems that with the old cam this was sitting inside the opening on the timing cover, now it's not. However, I installed the oil pump gears and aligned it with the distributor and it is engaging in the slot. The gear won't turn and I can hear the distributor clicking as I jiggle the gear. Any of this sound weird or is this normal?
distributor
