Limited Slip or Locking Differential - Page 2 - Defender Source
Old December 15th, 2014, 05:10 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Z.G View Post
Very locked sir
Dang, that's surprising. I met him once; he's funny guy.
Old December 15th, 2014, 05:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
He doesn't use it very often, but SCARR got some heavy rain this year and turned into grease. Still had to winch
Old December 15th, 2014, 05:23 PM
jafir's Avatar
jafir
Jafir Elkurd
Very locked sir
I asked him not to use them, just teasing a bit, when he was showing some of us less experienced drivers some tricks. He complied.
Old December 15th, 2014, 10:20 PM
Buddy Lee
Tobias
TBD
Originally Posted by LR Max View Post
I'm against selectable lockers. People either wait too late to engage them and THEN get into trouble, or just assume that their air lines/compressor/compressor wiring works and then get into trouble and oooohhhhhh you ain't got nothing.
You could do the Toyota 8" conversion. Those selectable lockers are more reliable, but engage them BEFORE you need them.
So many times I've been wheeling and on a hill climb and people wait until the stop forward motion THEN engage their lockers...but are still stuck. When locking it up would've just gotten them through. Also I had to stop and everyone else behind me. Now everyone is stuck. Good job...
The problem here is not with the selectable lockers but with the person using them. You have to know how to use them and understand what your truck is capable of. I make the call before each obstacle based on the condition if I'm going to lock before or after. If it's a steep slick hill climb that I could be awkward to slide back down. I'll lock up before going up. However, if it's a rocky area or smaller obstacle that will allow me to stop and lock w/o endangering myself or my truck I'll try and make it open first and will only lock after I start to get wheel spin.
I've run the following combinations in my truck Open/Open, TT/TT, TT/Detroit and now Selectable/Selectable. The last combination is by far my favorite, but it's also a dedicated trailer queen now and spends more time on the trail than the road.
But basically I agree with the comments that you should get to know your truck and how to drive well off road. There have been many times where I've gotten people past obstacles simply by giving them a couple of pointers.
Old December 15th, 2014, 11:20 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I ran mine with a Detroit in the rear for a year then put the TT up front. It handled better with just the Detroit in the rear as I get some torque steer with the TT up front.
Old December 15th, 2014, 11:47 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Agreed...equipment is useless unless you know what you're doing
Old December 15th, 2014, 11:52 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Like most people say, tires will make the biggest difference. Then learn how to drive off road. I've been open diff for 7+ years and have been all over the U.S. And Canada in all different situations. 31" or 33" Mid Terrain will make you unstoppable off road.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 16th, 2014, 12:17 AM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Thank you for all the input. I have absorbed about 95%. I just talked to my tire guy today and started the tire conversation for the next LR.
Sticking to subject at hand, I understand that when you lock a diff, it's like a straight axle- both wheels on the axel turn synchronize.
From my understanding (and experience with a LSD on a rear wheel drive car in the snow) one wheel slips and the diff transfers the energy to the wheel with the traction. I imagine that each manufacturer has a different design so they will run differently on the trail. Still the principal should be the same.
Where I am confused: what is a selectable? Is a 'locker' and a 'locking' diff the same? Toyota what? LSD going sideways on snow - that sounds like the opposite to what physics tells us a LSD does. And last are there different versions on LSD?
Old December 16th, 2014, 12:20 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Here you go.
Old December 16th, 2014, 01:51 AM
petminded's Avatar
petminded
David
Thanks for the ARB endorsement.
Old December 16th, 2014, 04:45 AM
Strangely it just occurred to me to ask - is there a clutch-type LSD available for the Defender?
Old December 16th, 2014, 07:40 AM
KAM do one.
Old December 16th, 2014, 08:58 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Thinking some here need a refresher on how the truetrac can be engaged if one wheel is completely unloaded. This guy's SIII provides an example:
http://youtu.be/0uwpNpvsshQ
Or can distribute power applied as necessary:
http://youtu.be/lZmsY2YvVsc
Old December 16th, 2014, 09:08 AM
psykokid
Jake
1997 Disco
That's why a later D2 with a set of truetracs performs pretty good offroad. The traction control and abs modulation help the unit lock up and give you that extra bit of traction.
Old December 16th, 2014, 10:08 AM
cbfritz_03
Carmen
none
Originally Posted by down_shift View Post
Thinking some here need a refresher on how the truetrac can be engaged of one wheel is completely unloaded. This guy's SIII provides an example:
...want.
Old December 16th, 2014, 10:13 AM
delete
Old December 16th, 2014, 10:54 AM
Except in the Pit of Despair, when the lockers aren't working and the winch cable is broken
Old December 16th, 2014, 11:53 AM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Originally Posted by ren ching View Post
except in the pit of despair, when the lockers aren't working and the winch cable is broken
hahaha.
Old December 16th, 2014, 01:05 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
It really depends what you're after, but IMO there is no argument that a Selectable locker rules. I can't think of any situation where a selectable would not be as good or better than an auto-locker or LSD.
I run Ashcrofts front and rear off a Puma compressor with 1.5 gallon tank and pneumatic switches. The only time I've had a failure is when I installed the airlines too close to the exhaust headers and blew a line. Though it was my fault, I did have spare air line and push-to-connect couplings so in about 2minutes I had my lockers back.
Old December 16th, 2014, 01:13 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I would say LSD is better on off camber sections as well as medium speed snow/sand
Can anyone confirm that a 95 Disco 1 came with a rear limited slip CDeWan Defender Technical Discussions 7 January 22nd, 2009 03:49 PM
Truetrac Limited slip Anyone want to let one go? CDeWan Wanted 10 November 6th, 2008 06:53 PM
D-90 Source/WhiteDog Comics Inc Limited Edition Gear chrisvonc The Vendors Loft 50 July 17th, 2007 02:34 PM
2003 Toyota 4Runner V8 Limited 4WD $23000 crown14 For Sale - Vehicles 0 December 21st, 2006 12:53 AM
