lights out on auto transmission assembly - Defender Source
Old January 30th, 2006, 09:50 PM
cafemosaic's Avatar
cafemosaic
steven n
1997 D-90 ST, AA Yellow
the lights are out on the shifter in my 97... i can get the trim plate off but not sure how to get to the bulbs on each side of the T handle...
also... the bulb for my tach is out... is there an easy way to get to it??
thanks much
Old January 30th, 2006, 10:20 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Might as well replace with LEDs
"It's not a Jeep"
Old January 30th, 2006, 10:38 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Hope you have skinny arms. Remove the six screws to the tray under the arm rest, then reach down and pull the bulbs. Reverse to replace....
Instrument cluster is super easy to pull. Two screws on the side and two on the bottom.
Old January 31st, 2006, 01:24 PM
cafemosaic's Avatar
cafemosaic
steven n
the screws under the armrest, do you mean inside the bin? i dont see a way to get to the bulbs under the trim plate from behind..
thanks much
Old January 31st, 2006, 01:43 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes, open the arm rest, remove the tray, reach down the side of the radio. Easy to access, just need long, skinny arms.
assembly, ht, lights, transmission
'94 Disco auto transmission problem cgalpin Defender Technical Discussions 19 July 27th, 2006 10:20 AM
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
Auto transmission gonewheeln Wanted 4 August 14th, 2005 02:23 PM
Rebuilt ZF auto Transmission mudrover For Sale - Parts 6 September 28th, 2004 02:45 PM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
