Lights Out - Defender Source
Old October 12th, 2004, 11:58 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Lights Out
Went to get some take out tonight and none of my lights were working headlights, taillights, dash lights all out. Checked the fuses and they all look good to go. Any ideas before I take it to the stealership.
Thanks in advance!
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old October 13th, 2004, 12:31 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Totally weird.
Joe, don't take it to the dealer. Take it to Eddie Bostock at West Coast Rovers in Irvine. He's the grandmaster. And he is a serious off-roader with a beastie RR rock-crawler.
DW
Old October 13th, 2004, 01:37 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Check your switch...easy enough to check. Even jump it--takes only a second or two.
Old October 13th, 2004, 01:45 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Sounds just like what happened with my 97, the switch is light plastic where the headlight contacts sit, they get hot and it melts the plastic.
When the switch died on my 97 I could still hold my brights on, you might want to see if still work if you pull the arm towards you. Mine died on me in Moab and I had to rig it with a toggle switch for the rest of the trip.
Old October 13th, 2004, 10:30 AM
artm
Arthur Maravelis
97 SW
Since the 97 switch has a different connector, and a higher price tag, I used a 94-95 and spliced into mine.
94-95.......PRC3430...........$40
97.............AMR6104..........$90
www.northeastbritishparts.com
Old October 13th, 2004, 11:14 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Sounds like a good time to wire in a relay.
JP
legend in my own mind
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
If you pull off the plastic housing around the steering column you may find that the contact on the switch is loose or broken. Its a lot easier than chasing wires.
Old October 13th, 2004, 12:21 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
I checked this morning and the brights do work, but nothing else.
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
