Lights out! - Defender Source
Old November 19th, 2009, 12:05 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Lights out!
The lights went out in my D last night. No parking/dash/headlights. Offroad lights still work, as well as the 'brights flash' when you pull back the turn signal lever. Everything else on the truck seems fine (electrically anyway!).
I've had this happen before and it was the headlight switch, which I replaced. So last night I bypassed the switch (disconnected it and tried jumping the wires) but I didn't get any lights, nor any apparent voltage - there appears to be no power getting to the switch.
Fuses, while unlikely (since things are on different fuse circuits), were checked next and are all good.
The only thing I can think of is either a melted wire somewhere in the wiring mess or a bad ignition switch. I was thinking ignition switch because it's required to be 'on' for the headlights to be 'on' so it's in the path... however, that does not explain why the dash/parking lights won't come on, which don't require the ignition switch to be 'on'. One thing suspicious about the ignition switch is that it seems pretty worn out - it no longer 'springs back' well from 'start' to 'run' and I have to give it a little help back or the starter will stay engaged... it feels a little loose/sloppy.
Any other thoughts?
Old November 19th, 2009, 07:28 PM
It has to be a fuse, relay or the switch.
Old November 19th, 2009, 10:12 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
A buddy of mine was driving my 90 one time - he accidently hit the switch with his knee and it stopped working. But look at switch first and make sure the emergency flasher is not half way between on and off.
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
