Lighting issue - Defender Source
Old December 28th, 2013, 05:05 PM
Sparky
Jim
1999/90
Lighting issue
My Defender 90 (1999) when the engine is running and I put my foot on the brake pedal, the dashboard lights and front headlights and side lights come on dimly. And when I put my side lights on, my brake lights come on. I've cleaned the earths under the drivers seat and added some new ones, disconnected the battery and wire brushed the chassis terminal to get a good connection. Also disconnected and cleaned where it connects to the gearbox but this doesn't seem to have solved the problem. Are there any other earthing points that I could clean or any other ideas?
Old December 28th, 2013, 05:26 PM
I had some odd lighting issues on mine and it ended up just being corroded connectors near the headlamps. I would just start checking connectors for all the lights to make sure they are fully seated and clean.
Old December 28th, 2013, 05:39 PM
ArlowCT's Avatar
ArlowCT
Ryan Lowe
1973ish SER III, 88"
Sounds like its a bad ground for the brake/tail lights. The power is running from the brake peddle through the brake lights and it should go to ground but it's not making it. It's running up the ground wires into the other circuits. Use a ohm's meter and start looking at everywhere there is a ground near the lights.
Old December 28th, 2013, 08:31 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Check the bulkhead for another ground location.
Old December 29th, 2013, 01:23 PM
Sparky
Jim
1999/90
Thanks guys. I'll give all your ideas a go and see how I get on.
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
intirior lighting Rover- Girl Defender Technical Discussions 1 October 14th, 2005 10:59 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Fuel Pump Issue bjenk Defender Technical Discussions 12 December 5th, 2004 09:00 PM
