Light switch bad? - Defender Source
Old May 21st, 2010, 09:32 AM
Hazard's Avatar
Hazard
David Hazard
95 D-90
Light switch bad?
My headlights and dash lights stopped working when I was out the other night. I parked the car and when I turned it back on, the lights werent working.
The light switch in "running light" position works, running lights turn on and dash lights turn on. But the light switch in the on pistion turns all of that off. No lights, running lights or dash lights. However if I pull the turn signal lever to the brights position, the bright headlights turn on.
I checked all the fuses and I'm guessing a light switch. Anyone have any thoughts or experience?
Thanks.
95 D-90 3" lift, 35" Baja claws, salisbury rear axle, 4.88 gears, lockers, winch, etc
Old May 21st, 2010, 10:39 AM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
Light switch , did you upgrade the headlights ?
Old May 21st, 2010, 12:13 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
I didn't. Stock headlights. I'm betting it's the light switch
Old May 25th, 2010, 11:11 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
So I'm looking for a replacement switch and the ones overseas look to be the best price. One question, the switch ad says "Defender Master Light Switch from VA chassis onwards"... is my NAS a VA chasis or will this light switch work?
Here is the link: http://www.brookwell.co.uk/item/876/...r-light-switch
Thanks guys!
Old May 26th, 2010, 11:44 PM
Hazard's Avatar
Hazard
David Hazard
95 D-90
anyone?
Old May 27th, 2010, 12:11 AM
VA is after 1995.
RA is 94, SA is 95 TA is 96 VA is 97 (not 100% sure but the interwebs will tell you if I am exactly right).
So no, the connector is different.
Old May 27th, 2010, 07:54 AM
Mine went out years ago and I keep using it. Try playing with the positioning, go very slow and at some point, it should turn the lights on.
You can also take it out and clean the contacts.
Old May 27th, 2010, 09:19 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I think it is a right of passage as a D owner at some point, among other things. Driving at night with no lights or just running lights due to a bad switch.
Buy two when you do find the right one. Carry a spare.
ht, switch
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
Head light switch repair - Is this 4 real? paulb Defender Technical Discussions 11 March 17th, 2010 02:53 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
