Lifter noise on Startup only D90 NAS - Page 2 - Defender Source
Old May 18th, 2017, 11:07 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Wait, there are trucks that don't make Lifter noise on startup?
1995 Defender ST
2008 LR3 HSE - Family Truckster
Old May 18th, 2017, 12:52 PM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
If you use a heavier weigh oil, like 15-50, you'll def get some tapping noise at start up due to the ticker flow. But it's a good oil to use , esp if your truck lives in higher temp climates; say... Vegas in the summer months.
I've started putting a bottle of liquid moly oil additives with oil change.
Old May 18th, 2017, 01:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I use Crane Lifters and they DEFINITELY make noise on start up--but only for 5 seconds or less...
Old May 18th, 2017, 08:42 PM
Originally Posted by lithium1330 View Post
You'll want to pre-fill the filter and let the filter element soak up the oil. Pour oil into the filter to about 3/4 way to top, wait a minutes, the oil level in filter should drop/lower. Repeat until oil no longer drops, but stays at 3/4 full in the filter housing.
Remember to also wet the rubber seal/gasket with some oil before spinning the filter back on.
You shouldn't have much spillage (if at all) since you're only tilting the filter slightly.
This is the right way to do it - but i just fill 3/4 up and wait a minute or so then put it in..
important thing is that your not going in dry...
anyway - an oil change takes 20 minutes or so and is really easy - just watch where you put the pan when you drain it out - and i hold the sump plug to direct the oil away from the exhaust - you'll see what i mean
95' D90 - Mostlydaily driver..
Old May 19th, 2017, 05:49 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Is 0W-40 Mobil1 not a thing anymore? That's always been the defacto for the Rover V8, hasn't it?
Old May 20th, 2017, 11:20 PM
They dropped the ZDDP levels in it.
Old May 21st, 2017, 08:49 AM
cellulararrest
Chris Snyder
Damn I'm out of the loop I guess. Time for an oil change
Old May 21st, 2017, 11:32 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
RP claims ZDDP-rich is problematic for flagship status. E.g., I havta call my local O'Reillys for next-day pickup to get RP HPS, but the one with less ZDDP is a store-stock item.
Old May 22nd, 2017, 07:27 AM
Amsoil 10w40 has the appropriate levels of Zinc, Ive been using this for years
Old May 22nd, 2017, 09:12 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Rotella every 3000 miles.
The 15W-40 Rotella T with Triple Protection oil has approximately 1200 ppm of zinc and 1100 ppm phosphorus at the time of manufacture.
Old May 22nd, 2017, 09:34 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ this ^^
My local buddies have torn down their motors after years of running this oil and they are never sludgy inside.
My Rovers always have some noise on startup after a few days of sitting.
Goes away in 10 seconds or so.
Rent my
Old May 22nd, 2017, 10:12 AM
DiscoDavis
Davis
1990 110, 1995 Disco
3rd on the Rotella
both the tdi and the 3.9 run 15w40. It works guuud
Old May 22nd, 2017, 10:18 AM
lithium1330
'97 SW NAS 4.6
Speaking of Shell Rotella, do you guys know the ZDDP level in the T6 synthetic oil?
I've been using M1 10w40 synthetic... and not sure if I should switch to Shell.
Old May 22nd, 2017, 05:01 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by DiscoDavis View Post
3rd on the Rotella both the tdi and the 3.9 run 15w40. It works guuud
4th on Rotella. I've not been using it forever but I'm running three rovers on it currently. Home Depot has a good price for 4qts jugs @ $13. Advanced Auto matches their price if you ask them to.
Old May 22nd, 2017, 06:02 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 22nd, 2017, 06:11 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Eastwood offers a ZDDP additive to help flat tappet engines. I run it in my E-type with no issues.
Angus
90, d90, nas, start
Any NAS D90 rough/project dnewman9 Wanted 11 October 12th, 2012 03:06 PM
NAS D110 Parts New and Used, some D90 parts colorover For Sale - Parts 27 May 5th, 2011 04:11 PM
'95 NAS D90: Ready for the Rubicon or rush hour... KG6BGJ For Sale - Vehicles 0 September 17th, 2005 07:23 PM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 03:20 PM
